info in interface brief
hi
it may be simple but why its showing manual,NVRAM,TFTP for different interfaces ??
FastEthernet2/0 YES manual up up
FastEthernet2/1 unassigned YES NVRAM administratively down down
Virtual-Access1 unassigned YES TFTP down down
regds
prem
Silver
Re: info in interface brief
This defines the method by which the interface was configured, manual indicates that someone has entered config mode and configured the interface, NVRAM indicates that the interface was configured from memory (usually when the router was reloaded) and TFTP indicates that the config for the interface was TFTP'd into the router.
I made this int manually down then y its showing TFTP ,it shuld show manual .pls clear this point..
Serial4/0 unassigned YES TFTP administratively down down
Regds
prem
96
