Community Member
Info not showing up properly in Cisco Network Assistant? Pic...
http://members.shaw.ca/ccslai/cgi-corp-cwbb.jpg
Ignore the layout as we are reconfiguring and moving the connections so that it will be cleaner.
At any rate, the switches with the "?" are either 2948G-GE-TX or 2948. How do I go about so that Cisco Network Assistant 3.0 recognizes them as switches and can see them like the other switches?
Is there something I have to turn ON on those switches? Does them having CatOS has something to do with CNA 3.0 not being able to recognize them?
1 REPLY
Red
Re: Info not showing up properly in Cisco Network Assistant? Pic
CNA only supports switches running IOS
Check out the minimum software requirements:
http://www.cisco.com/en/US/products/ps5931/prod_release_note09186a008051d2cf.html#wp699844
132
