Info on Be, Bc for Frame-Relay
somanabich
Can anyone point me to info on these parameters when configure Frame-Relay Traffic Shaping?
Are these values derived from my AR and CIR or is there some calclulation that I mus perform.
Any help appreciated.
5 Replies 5
mmikhail
• Tc—Committed Rate Measurement Interval
(Bc/CIR)
• Bc—Committed Burst Size
• Be—Excess Burst Size
• CIR—Committed Information Rate
• MinCIR—Minimum Committed Information Rate
Thanks Guys.
However I would still like some clarification.
I have two (for now) remote site that have CIR=40, AR=64. The central site has a AR=512K.
Would I configure the Central router as follows;
interface serial 0
no ip address
encapsulation frame-relay
frame-relay traffic-shaping
frame-relay class my_class
interface Serial0.1 point-to-point
description VC to remote site 1
ip address 192.168.245.254 255.255.255.252
frame-relay interface-dlci 16
description VC to remote site 2
ip address 192.168.245.250 255.255.255.252
frame-relay interface-dlci 17
map-class frame-relay my_class
frame-relay adaptive-shaping becn
frame-relay traffic-rate 40000 64000
Is this correct? Any help appreciated.
Yes, the sub-interfaces inherit the class from the main interface. If you want to add a new sub-interface with different parameters create a new class then apply the new class directly to the sub-interface.
Thanks for that.
However have I got the details of class correct, i.e. Do I throttle the bandwidth of the main router sub-interface to correspond to the remote routers AR and CIR?
Also, are Be and Bc assigned by Frame-Relay Service provider for each of my PVCs?
