Info reqd on Trace command
is ther anyway to change the packet size of tracert command being used from command prompt of our PC??we can use different byte size for pinging is ther any options available like that to change the packet size.
prem
VIP Purple
Re: Info reqd on Trace command
Hi Prem,
AFAIK this is not possibe. Just out of curiosity, why would you want to change the packet size of the trace ? What do you want to accomplish ?
Georg
hi george
we hve put route map in place in all interface due to which i m unable to trace some of the customers lan ip.since i m doing this from my pc and not from my routers always.though pc is using 92byte packet for trace its getting blocked whenever i trace.to avoid the same i need to increase the byte size and chek.
prem
105
