Webcast-Catalyst9k
Inline Power With AP350
I have a C6509 with inline power modules. This modules works with Access Points 350(Inline Power) , or only IP Phones?
What I need to configure on Switch!?
Thanks!
1 REPLY
Bronze
Re: Inline Power With AP350
Power to the AP350 is supplied through the cat 5 cable to the ethernet port (there is no seperate power socket). There is nothing to be confiugred on the switch... when the AP boots up, it sends a cdp packet to the switch which allows the switch to supply the requested power. Support for inline power begins in 12.1(13)E.
http://www.cisco.com/warp/public/102/wlan/350power-21480.html
96
