Community Member
Input and CRC errors on uplinked switches
I currently have two adjoining switches that are having excessive input and CRC errors. One switch is a Cat 2970 and the other is a Cat 3548. I've included the config output and port stats for each switch interface. Does anyone know what could cause these conditions?
FastEthernet0/6 is up, line protocol is up
Hardware is Fast Ethernet, address is 0002.b963.9ac6 (bia 0002.b963.9ac6)
Description: Uplink to 10.50.1.4
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 54/255, rxload 20/255
Keepalive not set
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:54, output hang never
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 8224000 bits/sec, 2542 packets/sec
5 minute output rate 21354000 bits/sec, 3010 packets/sec
3547425034 packets input, 1949288603 bytes
Received 111173371 broadcasts, 0 runts, 0 giants, 0 throttles
46 input errors, 46 CRC, 0 frame, 638 overrun, 638 ignored
0 watchdog, 50626384 multicast
3186994272 packets output, 4199136339 bytes, 25174 underruns
0 output errors, 0 collisions, 3 interface resets
Current configuration:
interface FastEthernet0/6
description Uplink to 10.50.1.4
duplex full
speed 100
end
GigabitEthernet0/1 is up, line protocol is up
Hardware is Gigabit Ethernet, address is 000d.28cd.7381 (bia 000d.28cd.7381)
Description: Uplink to 10.50.1.5
reliability 255/255, txload 43/255, rxload 23/255
Keepalive set (10 sec)
input flow-control is off, output flow-control is off
Last input 00:00:13, output 00:00:01, output hang never
Output queue :0/40 (size/max)
5 minute input rate 9237000 bits/sec, 1841 packets/sec
5 minute output rate 16910000 bits/sec, 2609 packets/sec
3184464966 packets input, 2088649959 bytes, 0 no buffer
Received 22332005 broadcasts, 0 runts, 0 giants, 0 throttles
24345 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 630182 multicast, 0 pause input
3545026242 packets output, 741171459 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
Current configuration : 108 bytes
interface GigabitEthernet0/1
description Uplink to 10.50.1.5
no ip address
duplex full
speed 100
end
Blue
Re: Input and CRC errors on uplinked switches
these issues can be caused by faulty type patch/link cables or other physical layer issues.
the fact that you have GB >>> 100mb port makes me wonder if you get the same issues with 100mb >>> 100mb. if so, replace the patch cables or check the 'inside' wiring between the switches for faults or anomolies.
are you CAT5e on both sides, all the way through or do you have other CAT type cables in the mix? try a single specification end-to-end if you can.
Purple
The first thing you need to do is clear the counters , according to your display they have never been cleared so you really don't know how long a period of time this is over , probably since the last time the switch was rebooted whenever that was , clear both sides then watch it . The errors could have been caused when you hooked the link if had a temporary speed/duplex mismatch or something . Clear counter s and watch for a week .
Community Member
You may be running into this problem on the 3500 :
http://www.cisco.com/en/US/products/hw/switches/ps607/products_field_notice09186a00803278b7.shtml
It's worth checking the serial numbers just in case.
Dave
154
