12-09-2003 12:21 PM - edited 03-02-2019 12:14 PM
After I installed the IOS I lost the command to configure the fast ethernet ports. Uhh did I miss something? Im still learning, but I did en / conf t / int f 0/0 and it says there is no fast ethernet there anymore. :(
Did something change in that version? If I cant reconfigure the f-e's I cant ftp a new IOS to fix the problem. Im consoled in now, via a laptop /usb /console patch cord. How can I get my fe's back?
Solved! Go to Solution.
12-09-2003 08:02 PM
Try the following URL.
Good luck,
12-09-2003 12:57 PM
which platform are you using ? Can you post the result of´the ´show version´ command ?
Georg
12-09-2003 01:03 PM
Its a 2651XM
and
IOS Version 12.2(10)Release Software (fc2)
I dont have a printer or a disk drive on the terminal. :( I can retype the whole thing if it will help.
12-09-2003 05:34 PM
well Im gonna blow it away and just reload another IOS. For some reason its not seeing any of the interfaces other than the console and the aux. Very odd. I dont know why it wont see any of the interfaces, but needless to say ive had a frustrating day.
If anyone has any other suggestions, id like to hear em.
12-09-2003 06:31 PM
Im going nuts. Since it wont recognize anything other than the console and the aux ports, I cant set up a tftp or ftp b/c there is no way to set up an interface to assign an ip address to.
Does anyone know how to push an IOS through the console port connected to a win/hypterm laptop?
12-09-2003 08:02 PM
Good luck,
12-10-2003 07:47 AM
Thanks for the link. Unfortunately I am not able to get there, and I cant get anyone in customer support to help me get my corporate account fixed, service contract made, or for that matter, return an email. :(
I ended up doing a ctrl+break and xmodem'ing the ios to the router through the console cable. It took 45 min, which is less time than I thought it would. Im getting closer and its working. If there is a pdf that you can send me, that would be great. Otherwise I cant access the link. They wont let me in.
12-10-2003 08:13 AM
Ok Im a moron. I found a way to get to the link. For some reason when I clicked on the link, it said it was only for a level above what I was authorized for (guest).
So I looked at the URL and figured out that if I go through the main page, products, routers, cisco 800 series routers, under tech docs / configuration guides, cisco 800 series software config guide, upgrading cisco IOS software, there it is, how to upgrade a IOS from the console port by doing CTRL+Break and the ROM (tiny rom)
I figured out how to do it the hard way, but this helps alot. Thanks for taking the time to help me out. I dont know if the IOS works yet, but at least I can get a new IOS to the router. Its wierd that this works even though I have a 2651 and this doc is listed under the 800 series. I guess its supposed to work for everything. I do know it works for me.
Thanks again.
