Interface backup which stays up and without using a routing protocol
we want to use an ISDN interface a backup for a serial interface on a cisco router. the problem is:
1- the link can be down while the primary interface stays up.
2- We can't use any routing protocol beween the router and the equipment behind the link.
So we can't use floating static route or dialer watch
Is there any other mean to trigger the backup link when the other side equipment becomes unreachable through the primary link?
1 REPLY
Anonymous
N/A
Re: Interface backup which stays up and without using a routing
Not really. If this is a FR link,
you could use end-to-end keepalives
to ensure that the primary goes down
in the event of any link failure.
You might also look into snapshot routing
on the serial link, if you are
concerned about the routing overhead
(although a link state protocol would
be better).
84
