Interface Broadcast
dian.it
Hello, when i run sh int s0 (Encapsulation rame Relay) in my router i saw a INTERFACE BROADCAST parameter with value different to cero. But i run command NO IP DIRECT-BROADCAST over interface and INTERFACE BROADCAST parameter already continue ascending . What is the reason?
ciscomoderator
Community Manager
Community Manager
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
nuno.morais
Hi.
Are you running any routing protocols over the frame-relay link?
"no ip directed-broadcast" is used to tell an interface not to forward packets destined to a subnet broadcast address.
Hope this helps.
NM
