Webcast-Catalyst9k
Interface counters show zero input/output
What does it mean when you see this all the time on your catalyst 2950 switch even though the switch is passing traffic?
Re: Interface counters show zero input/output
It means that there is very little traffic. Please note that the counter is an average over the last five mins.
When the five-minute interval is below one packets/s it is rounded down to zero.
I cleared the counters on the interface and watched over five mins and the 5 min input/output still shows zero. See below:
FastEthernet0/17 is up, line protocol is up
Hardware is Fast Ethernet, address is 000a.f465.5891 (bia 000a.f465.5891)
MTU 1500 bytes, BW 100000 Kbit, DLY 1000 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
input flow-control is off, output flow-control is off
Last input 00:00:10, output 00:00:01, output hang never
Last clearing of "show interface" counters 00:05:52
Queueing strategy: fifo
Output queue :0/40 (size/max)
126 packets input, 15627 bytes, 0 no buffer
Received 6 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 6 multicast, 0 pause input
3554 packets output, 1344813 bytes, 0 underruns
149
