Interface issue
COuld someone please explaing the following to me and how I can fix it?
When doing a "show interface" on my pix firewall (515e) I get:
interface ethernet0 "outside" is down, line protocol is up
Would a reboot fix it?
Dan
Re: Interface issue
The outside interface may be administratively down. (new installation?)
When there is an active link connected you get this weird message. Use the command "interface ethernet0 auto" to bring it administratively up.
Leo
Re: Interface issue
Other than being administrativly down im not sure how this is possible. Line proto is up so carrier must be available and nor is it shutdown.
Could you post output of show interface ethernet0?
You could try config t > interface ethernet0 shutdown then interface ethernet0 auto to bring it backup.
Re: Interface issue
Thanks for the reply
sh interface ethernet0
Hardware is i82559 ethernet, address is 0003.6bf7.1d1e
IP address 212.113.17.4, subnet mask 255.255.255.224
MTU 1500 bytes, BW 100000 Kbit full duplex
1813500 packets input, 130404094 bytes, 0 no buffer
Received 427629 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
792871 packets output, 47593897 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/8)
output queue (curr/max blocks): hardware (0/2) software (0/1)
Currently this pix (primary) is not active as the standby has become active.
I might need to this out of hours if there's a risk of network downtime. Is there a risk with this?
Dan
Re: Interface issue
This should be ok if the standby has taken over. Perhaps that is why the outside interface is showing this state.
Re: Interface issue
Try giving no shut on the interface. if the cable is plugged in incorrectly it keeps the line protocol down.
112
