interface on cisco 1721
i have a cisco 1721. On this i install a WIC-4ESW card. The problem ist that when i try to configure an ip address on this card (any port) i get this message :
% IP address may not be configured on L2 links
Please, how can i configure ip address on this card ? Help !
1 ACCEPTED SOLUTION
VIP Purple
Re: interface on cisco 1721
the WIC-4ESW does not give you 4 additional Layer 3 interfaces, it gives you 4 additional Ethernet ports, so basically you are adding a 4-port switch to your router. You need to configure inter-VLAN routing on the 1721 in order for the ports to communicate...
Check this link as well:
Cisco HWIC-4ESW and HWIC-D-9ESW EtherSwitch Interface Cards
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802c6bb6.html
HTH,
GP
Purple
Create a SVI, interface vlan XXX and put the address there , then apply the vlan to the switchport.
VIP Purple
HTH,
GP
i have done this :
interface vlan2
interface vlan3
ip address 192.168.2.1 255.255.255.0
interface vlan4
ip address 192.168.3.1 255.255.255.0
interface vlan5
ip address 192.168.4.1 255.255.255.0
vlan database
vlan 2 state active
vlan 3 state active
vlan 4 state active
vlan 5 state active
apply
exit
interface FastEthernet1
switchport access vlan 2
interface FastEthernet2
switchport access vlan 3
interface FastEthernet3
switchport access vlan 4
interface FastEthernet4
switchport access vlan 5
After that, i try to ping each address ip from my pc but no response
GOOD ! it's ok now !
Thanks to all !
252
