11-04-2005 12:34 PM - edited 03-03-2019 12:41 AM
I'm trying to apply the same options to all the 24 interfaces on our 3524XL switch. It'll be a waste of time to do it one by one.
When I tried to enter the int range command it keeps saying it's an unrecognized command. Does anyone know how I can get it to work?
11-04-2005 01:00 PM
unfortunately, that command is not available for the 3500XL. I used to create text files using Microsoft Word...
HTH,
GP
11-04-2005 02:09 PM
Nope those are way too old to support that command .
