Interface Stats and Cache Flow Stats are different
Hello all,
i use a C2611XM in our Backbone. Version: IOS (tm) C2600 Software (C2600-IS-M), Version 12.2(13b).
At the Fa0/1(and only there) we use "ip route-cache flow". In Combination with "ip flow-export" we get an unrealistic sum of bytes passing this Interface at our accounting system. Please see the difference between the stats for "show interface fa0/1" and "show ip cache flow" (Totals Line; Total Flows * Flows/Packet * Bytes/Packet).
Any Help?
2611XM#sh int fa0/1
FastEthernet0/1 is up, line protocol is up
Hardware is AmdFE, address is 000c.3085.8d41 (bia 000c.3085.8d41)
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 3/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 1., loopback not set
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:08, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1519000 bits/sec, 147 packets/sec
5 minute output rate 44000 bits/sec, 97 packets/sec
57254718 packets input, 1178626299 bytes
Received 97654 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
43662515 packets output, 3143989358 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 lost carrier, 0 no carrier
2611XM#sh ip cache flow
last clearing of statistics never
Protocol Total Flows Packets Bytes Packets Active(Sec) Idle(Sec)
-------- Flows /Sec /Flow /Pkt /Sec /Flow /Flow
Total: 302092 0.3 189 1129 60.6 13.0 7.3
1 REPLY
Bronze
Re: Interface Stats and Cache Flow Stats are different
I think Netflow only supports IP traffic and it can capture only flows that are switched through the router, but not router generated traffic or other layer2 traffic like CDP, VTP or DTP messages that are exchanged. So you won't be able to see the same value between the two commands if you are using any such scenarios.
96
