Intergrated Routing and Bridging (IRB) over Frame Relay Subinterface
Hello all together,
we have a problem with an IRB Configuration via an Frame Relay Network.
I shortly explain what we have done:
We have 2 Routers connected via Frame Relay pt-2-pt Subinterfaces. At both Routers we have the IRB Feature activated. At one Router we have configured an BVI interface and linked at to the FR Subinterface. The other Router should only bridge the incomming packets from the serial interface (s1/2.40) to the outgoing LAN Interface (e0/0.40). In the LAN environment is the remote IP Address from the BVI 1 Interface.
But this is not working. We have the same scenario with an serial leased Line (ppp encapsulation) and that works fine.
Here are extracts from the configs:
Router 1:
bridge irb
interface Serial0/0
bandwidth 384
no ip address
encapsulation frame-relay
no ip mroute-cache
no fair-queue
bridge-group 1
bridge-group 1 spanning-disabled
interface Serial0/0.104 point-to-point
frame-relay interface-dlci 104
bridge-group 1
interface BVI1
ip address 192.168.90.22 255.255.255.252
ip classless
ip route 192.168.90.240 255.255.255.240 192.168.90.21
bridge 1 protocol ieee
bridge 1 bitswap-layer3-addresses
bridge 1 route ip
end
Router 2:
bridge irb
interface Ethernet0/0.40
no ip proxy-arp
bridge-group 40
bridge-group 40 spanning-disabled
interface Serial0/0
bandwidth 384
no ip address
no ip mroute-cache
no fair-queue
bridge-group 40
interface Serial0/0.40 point-to-point
frame-relay interface-dlci 40
bridge-group 40
bridge 40 protocol ieee
end
The DLCI is up and cdp information are already exchanged. What could be the reason that it will not work with Frame Relay encapsulation. Could it be a an problem with the address resolution or an IOS Bug?
As Appendix i ´ll provide you the output from debug arp, debug ip packets, debug frame-relay packets from Router 1:
ping 192.168.90.250
Sending 5, 100-byte ICMP Echos to 192.168.90.250, timeout is 2 seconds:
6d01h: IP: s=192.168.90.22 (local), d=192.168.90.250 (BVI1), len 100, sending
6d01h: ICMP type=8, code=0
6d01h: IP ARP: creating incomplete entry for IP address: 192.168.90.21 interface BVI1
6d01h: IP ARP: sent req src 192.168.90.22 0000.0c53.13a9,
dst 192.168.90.21 0000.0000.0000 BVI1
6d01h: IP: s=192.168.90.22 (local), d=192.168.90.250 (BVI1), len 100, encapsulation failed
6d01h: Serial0/0: broadcast search
6d01h: Serial0/0:encaps failed on broadcast for link 38(BRIDGE)
6d01h: Serial0/0.104: broadcast search
6d01h: Serial0/0.104(o): dlci 104(0x1881), pkt type 0x6558, datagramsize 64
6d01h: bridged dest ffff.ffff.ffff, src 0000.0c53.13a9, type 806
6d01h: broadcast dequeue
6d01h: Serial0/0.104(o):Pkt sent on dlci 104(0x1881), pkt type 0x6558(BRIDGE), datagramsize 64
6d01h: IP ARP throttled out the ARP Request for 192.168.90.21
6d01h: Serial0/0.104: Broadcast on DLCI 104 link 65(CDP)
6d01h: Serial0/0.104(o): dlci 104(0x1881), pkt type 0x2000(CDP), datagramsize 335
6d01h: Serial0/0.104(o):Pkt sent on dlci 104(0x1881), pkt type 0x2000(CDP), datagramsize 335
6d01h: Serial0/0.104(o):Pkt sent on dlci 104(0x1881), pkt type 0x6558(BRIDGE), datagramsize 64.
Success rate is 0 percent (0/5)
Thanx for any response.
Re: Intergrated Routing and Bridging (IRB) over Frame Relay Subi
1) Remove the bridge-group commands from the s0/0 interfaces, and only put them on the sub-interfaces.
2) Take the global bridge command out to bitswap the addresses (its not needed).
3) On router 2, remove the IRB since you're just bridging between the 2 interfaces and not routing the bridged traffic on this router ( If I misunderstood, then a BVI40 interface will need to be added on Router 2. )
3) The static IP route overlaps with the BVI /30 but that won't prevent things from working in a classless environment on this router, but if device on remote LAN has a /28 IP subnet address and no route back to this /30 network then they'll need to add one.
Is there a device on routers 2 LAN with IP of 192.168.90.21 / 30 and 192.168.90.x / 28 network??? If so, check to make sure both IPs are up. One might not be up since those ranges overlap. Cisco routers don't allow overlapped networks (except on serial interfaces) so...
HTH, Erick
Disregard my comment about the IP subnet overlapping. Sorry.... posted to quick and too early in the morning.
715
