Intergrated Routing and Bridging (IRB) over Frame Relay Subinterface
Hello all together,
we have a problem with an IRB Configuration via an Frame Relay Network.
I shortly explain what we have done:
We have 2 Routers connected via Frame Relay pt-2-pt Subinterfaces. At both Routers we have the IRB Feature activated. At one Router we have configured an BVI interface and linked at to the FR Subinterface. The other Router should only bridge the incomming packets from the serial interface (s1/2.40) to the outgoing LAN Interface (e0/0.40). In the LAN environment is the remote IP Address from the BVI 1 Interface.
But this is not working. We have the same scenario with an serial leased Line (ppp encapsulation) and that works fine.
Here are extracts from the configs:
Router 1:
bridge irb
interface Serial0/0
bandwidth 384
no ip address
encapsulation frame-relay
no ip mroute-cache
no fair-queue
bridge-group 1
bridge-group 1 spanning-disabled
interface Serial0/0.104 point-to-point
frame-relay interface-dlci 104
bridge-group 1
interface BVI1
ip address 192.168.90.22 255.255.255.252
ip classless
ip route 192.168.90.240 255.255.255.240 192.168.90.21
bridge 1 protocol ieee
bridge 1 bitswap-layer3-addresses
bridge 1 route ip
end
Router 2:
bridge irb
interface Ethernet0/0.40
no ip proxy-arp
bridge-group 40
bridge-group 40 spanning-disabled
interface Serial0/0
bandwidth 384
no ip address
no ip mroute-cache
no fair-queue
bridge-group 40
interface Serial0/0.40 point-to-point
frame-relay interface-dlci 40
bridge-group 40
bridge 40 protocol ieee
end
The DLCI is up and cdp information are already exchanged. What could be the reason that it will not work with Frame Relay encapsulation. Could it be a an problem with the address resolution or an IOS Bug?
As Appendix i ´ll provide you the output from debug arp, debug ip packets, debug frame-relay packets from Router 1:
ping 192.168.90.250
Sending 5, 100-byte ICMP Echos to 192.168.90.250, timeout is 2 seconds:
6d01h: IP: s=192.168.90.22 (local), d=192.168.90.250 (BVI1), len 100, sending
6d01h: ICMP type=8, code=0
6d01h: IP ARP: creating incomplete entry for IP address: 192.168.90.21 interface BVI1
6d01h: IP ARP: sent req src 192.168.90.22 0000.0c53.13a9,
dst 192.168.90.21 0000.0000.0000 BVI1
6d01h: IP: s=192.168.90.22 (local), d=192.168.90.250 (BVI1), len 100, encapsulation failed
6d01h: Serial0/0: broadcast search
6d01h: Serial0/0:encaps failed on broadcast for link 38(BRIDGE)
6d01h: Serial0/0.104: broadcast search
6d01h: Serial0/0.104(o): dlci 104(0x1881), pkt type 0x6558, datagramsize 64
6d01h: bridged dest ffff.ffff.ffff, src 0000.0c53.13a9, type 806
6d01h: broadcast dequeue
6d01h: Serial0/0.104(o):Pkt sent on dlci 104(0x1881), pkt type 0x6558(BRIDGE), datagramsize 64
6d01h: IP ARP throttled out the ARP Request for 192.168.90.21
6d01h: Serial0/0.104: Broadcast on DLCI 104 link 65(CDP)
6d01h: Serial0/0.104(o): dlci 104(0x1881), pkt type 0x2000(CDP), datagramsize 335
6d01h: Serial0/0.104(o):Pkt sent on dlci 104(0x1881), pkt type 0x2000(CDP), datagramsize 335
6d01h: Serial0/0.104(o):Pkt sent on dlci 104(0x1881), pkt type 0x6558(BRIDGE), datagramsize 64.
Success rate is 0 percent (0/5)
Thanx for any response.
Re: Intergrated Routing and Bridging (IRB) over Frame Relay Subi
"encapsulation failed" message is in your output - this means that the router knows on which interface it has to send the packet, but doesn't know how to do it. The reason for this is it can't find the remote routers MAC (show arp should have 192.168.90.21 as incomplete). Can you change both bridge groups to the same number, example 1?
Hope it helps.
Steve
There is encapsulation failure in the outgoing interface, so the problem should not be the remote router. But do your router config match the config of the frame-relay switch? e.g. maybe you need the command "encapsulation frame-relay ietf".
Best Regards
Teru Lei
I ´ve solved the encapsulation failed problem with an static arp entry in the Router. I think that both Router have a Problem to exchange arp or broadcast informations via frame relay. Although we configured the static arp it isn´t still not working.
This time we get an encaps failed on broadcast for link 38(BRIDGE). Has anybody an idea. ?
Here is the output of the debug commands again.
sending 5, 100-byte ICMP Echos to 192.168.90.250, timeout is 2 seconds:
6d00h: IP: s=192.168.90.22 (local), d=192.168.90.250 (BVI1), len 100, sending
6d00h: ICMP type=8, code=0
6d00h: Serial0/0: broadcast search
6d00h: Serial0/0:encaps failed on broadcast for link 38(BRIDGE)
6d00h: Serial0/0.104: broadcast search
6d00h: Serial0/0.104(o): dlci 104(0x1881), pkt type 0x6558, datagramsize 118
6d00h: bridged dest 00c1.2603.157f, src 0000.0c53.13a9, type 800
6d00h: broadcast dequeue
6d00h: Serial0/0.104(o):Pkt sent on dlci 104(0x1881), pkt type
0x6558(BRIDGE), datagramsize 118.rÿ
6d00h: Serial0/0(i): dlci 103(0x1871), NLPID 0x3CC(IP), datagramsize 72
Add the keyword "broadcast" at the end of your frame-relay interface-dlci 104 - so it will look like "frame-relay interface-dlci 104 broadcast". Add at both ends of the network.
Steve
The reason why it is sending broadcasts out the s0/0 interface because this also has a bridge-group defined which isn't needed it sounds like unless you have more then one frame connecion and rest of the DLCIs are on the s0/0 interface.
Anyway, if it's just the one DLCI on subinterface then remove the bridge-group commands on the s0/0 interface on both routers.
I had responded to this earlier, but now my post is gone. Hmm....
On router 2, IRB is not needed if you're not routing the bridging traffic on a BVI on that router. So remove bridge command from s0/0 and just put bridge command on subinterface and LAN interface.
Your BVi interface on Router 1 is a /30 subnet, so since router 2 doesn't have a BVI it looks like then the next-hop is a machine on the LAN at that location.
After the above changes, can you ping your next hop?
Hi all togehther,
we have done the changes that steve hast posted and removed the bridge Group from the serial Interfaces. But it still notworking.
The the next-hop is in deed a machine on the LAN at that location and we can´t ping it.
What makes this interesting is, if we use a serial leased Line with ppp encapsuluation it works fine and we can ping the machine on the LAN . With show bridge command at the Router 2 we see that packets will forward to e0.40 and s1.40 with the corresponding MAC Addresses. Fine:-)
But if change the serial encapsulation to FR or also X.25 we see also packets from the serial Interfaces corresponding MAC address not anymore from the ethernet Subinterface.
It seems to be maybe a broadcast /arp problem because FR and X.25 are both Non Broadcast Media.
If it were a point-to-multipoint subinterface I would suggest :
frame-relay map bridge 104 broadcast [ietf]
Steve
768
