InterVlan Routing Doesn't Function Properly with HSRP
I have the Following Problem
I have various Vlans created in my 6509 Switches
and im doing Inter-Vlan Routing in the same Switch with 2 Router Modules per Switch. I have configured HSRP in the 4 Router Modules.
The problem is that when i try to ping a host in a Vlan A from a host in a Vlan B , i can't pass the Router modules where i have the Intervlan routing proccess created.
if im in Vlan B i can reach the default gateway of Vlan B and Vlan A , because this is created on the same Router module of the switch , but i can't pass to a host in the Vlan A.
What could be the Problem?????
These vlan's are directly connected i don't have to configure Static Routes or Dynamic Routing Protocols.
1 REPLY
Re: InterVlan Routing Doesn't Function Properly with HSRP
Since you suspected that HSRP does no work properly with vlan routing. I would suggest that you should take HSRP off (with an outage notification of course) and see if your vlan routing does work or not. I don't know that your config is but from your description, I have a feeling that you might have misconfigured your vlan A clients.
92
