InterVLAN routing hardware limitations on 3550 and 3750
Hi!
Can you tell me is there any hardware limitations for InterVLAN routing on Catalyst 3550 and 3750 series?
How many VLANs can be routed without changing devices routing productivity?
1 REPLY
Bronze
Re: InterVLAN routing hardware limitations on 3550 and 3750
The maximum number of VLANs supported depends on the IDB limits of the device. As far as hardware limitations are concerned, I am not aware of any as long as the switch supports trunking. Please refer the following document for configuration help.
http://www.cisco.com/en/US/tech/tk389/tk815/technologies_configuration_example09186a008019e74e.shtml
983
