Intervlan routing in 6509 with MSFC2 & IOS features
My 6509 with MSFC2 is behaving strangely. Is it normal to see the prompt as MSFC-1(boot) with boot in brackets. I have configured Intervlan routing properly but does not work.
Also the i cannot enable routing of any kind, not even static routes.
MSFC-1(boot)(config)#ip r router ?
% Unrecognized command
MSFC-1(boot)(config)#router?
Whats going on here. ANy bright ideas would be appreciated....
Re: Intervlan routing in 6509 with MSFC2 & IOS features
The MSFC is in the boot mode. Check to see if you have a regular IOS in the MSFC2 bootflash or slot0:. Change the bootvariables to point to the regular IOS fille, set config-register to 0x2102 and save config and reload. But I suggest you save the start-up config before you do this. Here is an example.
6506-12a#copy startup-config bootflash:whatever
Destination filename [whatever]?
1463 bytes copied in 0.272 secs
6506-12a#dir
Directory of bootflash:/
1 -rw- 6916064 Jul 16 2002 12:04:13 c6msfc2-js-mz.121-2.E
2 -rw- 1577680 Jul 16 2002 12:09:07 c6msfc2-boot-mz.121-2.E
3 -rw- 6323225 Jul 31 2002 09:28:51 cat6000-sup.5-5-2.bin
4 -rw- 1463 Aug 11 2002 05:17:07 whatever
15204352 bytes total (385404 bytes free)
6506-12a#conf terminal
Enter configuration commands, one per line. End with CNTL/Z.
6506-12a(config)#boot system flash bootflash:c6msfc2-js-mz.121-2.E
6506-12a(config)#config-register 0x2102
6506-12a(config)#end
6506-12a#wr mem
Building configuration...
[OK]
6506-12a#reload
Hi prkrishn
Thanks for your help. It worked right away!!
I still have problems with my Intervlan Routing. It is a straight forward config. but doesnt work.
"show run" from MSFC Primary
sh run
Current configuration : 928 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname MSFC-1
boot system flash bootflash:c6msfc2-psv-mz.121-8a.E5
boot bootldr bootflash:c6msfc2-boot-mz.121-8a.EX
ip subnet-zero
interface Vlan100
ip address 155.120.210.1 255.255.255.0
--More-- no ip route-cache
no ip mroute-cache
interface Vlan101
ip address 155.120.208.1 255.255.254.0
no ip route-cache
no ip mroute-cache
interface Vlan102
ip address 155.120.212.1 255.255.254.0
no ip route-cache
no ip mroute-cache
interface Vlan103
ip address 155.120.211.1 255.255.255.0
no ip route-cache
no ip mroute-cache
interface Vlan107
ip address 155.120.217.1 255.255.255.0
no ip route-cache
no ip mroute-cache
--More-- router eigrp 10
network 155.120.0.0
auto-summary
no eigrp log-neighbor-changes
ip classless
no ip http server
line con 0
line vty 0 4
login
end
"sh tech" from MSFC before I resolved the MSFC issue
MSFC-1#show tech-support
------------------ show version ------------------
IOS (tm) MSFC2 Software (C6MSFC2-PSV-M), Version 12.1(8a)E5, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Mon 22-Oct-01 23:33 by eaarmas
Image text-base: 0x40008980, data-base: 0x415A4000
ROM: System Bootstrap, Version 12.1(4r)E, RELEASE SOFTWARE (fc1)
BOOTFLASH: MSFC2 Software (C6MSFC2-PSV-M), Version 12.1(8a)E5, EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
MSFC-1 uptime is 1 minute
System image file is "bootflash:c6msfc2-psv-mz.121-8a.E5"
cisco Cat6k-MSFC2 (R7000) processor with 114688K/16384K bytes of memory.
Processor board ID SAD05410664
R7000 CPU at 300Mhz, Implementation 39, Rev 2.1, 256KB L2, 1024KB L3 Cache
Last reset from power-on
X.25 software, Version 3.0.0.
Bridging software.
5 Virtual Ethernet/IEEE 802.3 interface(s)
509K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x0
------------------ show running-config ------------------
Current configuration : 742 bytes
version 12.1
no service pad
hostname MSFC-1
ip subnet-zero
interface Vlan100
no ip route-cache
no ip mroute-cache
interface Vlan101
no ip route-cache
no ip mroute-cache
interface Vlan102
no ip route-cache
no ip mroute-cache
interface Vlan103
no ip route-cache
no ip mroute-cache
interface Vlan107
no ip route-cache
no ip mroute-cache
ip classless
no ip http server
line con 0
line vty 0 4
login
end
------------------ show stacks ------------------
Minimum process stacks:
Free/Size Name
9564/12000 Init
2248/3000 EARL INFO CAPABILITY process
5300/6000 RADIUS INITCONFIG
4072/6000 IPC delayed init
5592/6000 IPC Zone Manager
8104/9000 DHCP Client
4188/6000 IPC register control port
Interrupt level stacks:
Level Called Unused/Size Name
1 270 8208/9000 Inband Interrupt
2 380 8180/9000 EOBC Interrupt
3 0 9000/9000 Management Interrupt
4 4873 8604/9000 Console Uart
5 0 9000/9000 Mistral Error Interrupt
7 26770 8604/9000 NMI Interrupt Handler
------------------ show interfaces ------------------
Vlan100 is up, line protocol is up
Hardware is Cat6k RP Virtual Ethernet, address is 0007.ec73.1bfc (bia 0007.ec73.1bfc)
Internet address is 155.120.210.1/24
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:00, output never, output hang never
Queueing strategy: fifo
Output queue :0/40 (size/max)
54 packets input, 3532 bytes, 0 no buffer
Received 54 broadcasts, 0 runts, 0 giants, 0 throttles
14 packets output, 4083 bytes, 0 underruns
0 output errors, 1 interface resets
Vlan101 is up, line protocol is up
Internet address is 155.120.208.1/23
Last input 00:00:01, output never, output hang never
50 packets input, 2600 bytes, 0 no buffer
Received 50 broadcasts, 0 runts, 0 giants, 0 throttles
9 packets output, 2214 bytes, 0 underruns
Vlan102 is up, line protocol is up
Internet address is 155.120.212.1/23
51 packets input, 2652 bytes, 0 no buffer
Received 51 broadcasts, 0 runts, 0 giants, 0 throttles
Vlan103 is up, line protocol is up
Internet address is 155.120.211.1/24
Vlan107 is up, line protocol is up
Internet address is 155.120.217.1/24
------------------ show controllers ------------------
Interface EOBC0/0
Hardware is Mistral EOBC
Encap size=14, hardware status=0x210840
IDB type=18, IDB state=4
Encap type=0x1
Error threshold=5000, Error count=0
Span encap size=0
revision=3, idb=0x41BB4338
mistral_eobc_ds=0x41BB6170, mistral_global_register=0x10020000
mistral_dma_register=0x30000000
rx ring entries=512, tx ring entries=512
rxring=0x72FF960, rxr eobc shadow=0x41C7CDC4
rx_head=220, rx_tail=0, rx_count=220
rx_inputs=0, rx_cumbytes=0
txring=0x73019A0, txr eobc shadow=0x41C7D5F0
tx_head=164, tx_tail=164, tx_count=0
tx_retry_error=0
MISTRAL REGISTERS:
soft_reset_cfg=0x000000
rxdscp_cnt=512, txdscp_cnt=0
rxwork_dscp=0x720, txwork_dscp=0x1EC0
dma_buffer_size_reg=0x000000
MISC GLOBAL REGISTERS:
global_cfg=0x20, mis_init_sts=0xF, tm_init_size_cfg=0x8000
dimm_parm_cfg_hi=0x000526, dimm_parm_cfg_lo=0x42040F5A
------------------ show process memory ------------------
Total: 91599424, Used: 11595324, Free: 80004100
PID TTY Allocated Freed Holding Getbufs Retbufs Process
0 0 107976 1852 10825552 0 0 *Init*
0 0 624 60616 624 0 0 *Sched*
0 0 17062428 2517688 2792 3028940 0 *Dead*
1 0 280 280 3808 0 0 Load Meter
2 0 232 0 7040 0 0 CEF Scanner
3 0 0 0 6808 0 0 Check heaps
4 0 248 0 7056 0 0 Chunk Manager
5 0 96 0 6904 0 0 Pool Manager
6 0 280 280 6808 0 0 Timers
7 0 280 280 6808 0 0 Serial Backgroun
8 0 0 0 6808 0 0 EnvMon
9 0 3728 3428 7508 0 0 ARP Input
10 0 280 0 7088 0 0 IPC register con
11 0 27776 0 6960 0 0 IPC Periodic Tim
12 0 96 0 6904 0 0 IPC Seat Manager
13 0 0 0 6808 0 0 HC Counter Timer
14 0 280 280 6808 0 0 DDR Timers
15 0 280 280 12808 0 0 Dialer event
16 0 160 0 6968 0 0 Entity MIB API
17 0 96 0 6904 0 0 SERIAL A'detect
18 0 96 0 6904 0 0 Critical Bkgnd
19 0 33288 7480 13276 0 900 Net Background
20 0 96 0 12904 0 0 Logger
21 0 13240 280 6896 0 0 TTY Background
22 0 0 0 9808 0 0 Per-Second Jobs
23 0 192 132 7000 0 0 SCP Multicast
24 0 96 0 6904 0 0 CWAN OIR Handler
25 0 96 0 6904 0 0 DSX3MIB ll handl
26 0 96 0 6904 0 0 CT3 Mailbox
27 0 96 0 6904 0 0 CE3 Mailbox
28 0 96 0 6904 0 0 MIP Mailbox
29 0 96 0 6904 0 0 vcq_proc
30 0 96 0 6904 0 0 HAL Mailbox
31 0 232 0 7040 0 0 Mistral Reset Pr
32 0 232 0 7040 0 0 ECC correctable
33 0 288 0 13096 0 0 IP Input
34 0 2136 496 8448 0 0 CDP Protocol
35 0 1280 840 7248 64 0 SCP async: TCAM
36 0 440 0 7248 0 0 SCP async: Fake
37 0 1000 560 7248 40 0 SCP async: RUN_C
38 0 192 0 7000 0 0 X.25 Encaps Mana
39 0 0 0 12808 0 0 frr_tunnel
40 0 1052 0 10404 0 0 IP Background
41 0 0 0 6848 0 0 SNMP Timers
42 0 0 0 6808 0 0 PPP IP Add Route
43 0 568 280 7096 0 0 Adj Manager
44 0 34256 9584 13924 0 0 CEF process
45 0 96 0 6904 0 0 IPC LC Message H
46 0 0 0 6808 0 0 HTTP Timer
47 0 33168 1744 13196 0 28 SCP Hybrid proce
48 0 0 0 12808 0 0 TCP Timer
49 0 0 0 12808 0 0 TCP Protocols
50 0 96 0 6904 0 0 RARP Input
51 0 0 0 6808 0 0 Socket Timers
52 0 29892 280 22804 0 0 DHCPD Receive
53 0 0 0 6808 0 0 IP Cache Ager
54 0 6860 6420 7248 1760 0 SCP async: [cfg]
55 0 42148 41876 7248 3796 0 SCP async: [mls]
56 0 1112 6008 13480 0 4552 L3 Manager
57 0 1828 1320 101936 0 160 Feature Manager
58 0 440 0 7248 0 0 SCP async: HA SR
59 0 440 0 7248 0 0 SCP async: HA SR
60 0 640 280 4168 0 0 HA SRM Master
61 0 640 280 4168 0 0 HA SRM Slave
62 0 248 0 7056 0 0 PAD InCall
63 0 376 280 12904 0 0 X.25 Background
64 0 0 0 6808 0 0 TCP Intercept Ti
65 0 472 280 7000 0 0 Tag Input
66 0 280 280 6808 0 0 LSP Tunnel Head
67 0 376 280 6904 0 0 Any Transport ov
68 0 96 0 6904 0 0 CWAN VLAN Proces
69 0 0 0 6808 0 0 CWAN-RP SCP Proc
70 0 376 280 6904 0 0 ETH/MPLS Backgro
71 0 602200 595060 20012 0 0 Exec
72 0 192 0 7000 0 0 Net Input
73 0 280 280 6808 0 0 Compute load avg
74 0 0 0 6808 0 0 Per-minute Jobs
75 0 720 280 7248 20 0 SCP async: Draco
77 0 0 0 6808 0 0 DHCPD Timer
78 0 152 0 6960 0 0 DHCPD Database
79 0 328 0 7136 0 0 CEF IPC Backgrou
80 0 900 352 7356 0 40 Slave Running Co
81 0 9860 6492 9576 0 0 Constellation Ba
82 0 96 0 6904 0 0 IPC RTTYC Messag
84 0 496 0 7324 0 0 SCP async: const
11593764 Total
------------------ show process cpu ------------------
CPU utilization for five seconds: 0%/0%; one minute: 1%; five minutes: 1%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
1 0 26 0 0.00% 0.00% 0.00% 0 Load Meter
2 0 6 0 0.00% 0.00% 0.00% 0 CEF Scanner
3 36 9 4000 0.00% 0.02% 0.00% 0 Check heaps
4 0 1 0 0.00% 0.00% 0.00% 0 Chunk Manager
5 0 1 0 0.00% 0.00% 0.00% 0 Pool Manager
6 0 2 0 0.00% 0.00% 0.00% 0 Timers
7 0 2 0 0.00% 0.00% 0.00% 0 Serial Backgroun
8 0 118 0 0.00% 0.00% 0.00% 0 EnvMon
9 0 4 0 0.00% 0.00% 0.00% 0 ARP Input
10 0 1 0 0.00% 0.00% 0.00% 0 IPC register con
11 0 120 0 0.00% 0.00% 0.00% 0 IPC Periodic Tim
12 0 1 0 0.00% 0.00% 0.00% 0 IPC Seat Manager
13 0 29 0 0.00% 0.00% 0.00% 0 HC Counter Timer
14 0 2 0 0.00% 0.00% 0.00% 0 DDR Timers
15 0 2 0 0.00% 0.00% 0.00% 0 Dialer event
16 0 1 0 0.00% 0.00% 0.00% 0 Entity MIB API
17 0 1 0 0.00% 0.00% 0.00% 0 SERIAL A'detect
18 0 1 0 0.00% 0.00% 0.00% 0 Critical Bkgnd
19 0 61 0 0.00% 0.00% 0.00% 0 Net Background
20 0 16 0 0.00% 0.00% 0.00% 0 Logger
21 0 116 0 0.00% 0.00% 0.00% 0 TTY Background
22 0 119 0 0.00% 0.00% 0.00% 0 Per-Second Jobs
23 0 2 0 0.00% 0.00% 0.00% 0 SCP Multicast
24 0 1 0 0.00% 0.00% 0.00% 0 CWAN OIR Handler
25 0 1 0 0.00% 0.00% 0.00% 0 DSX3MIB ll handl
26 0 1 0 0.00% 0.00% 0.00% 0 CT3 Mailbox
27 0 1 0 0.00% 0.00% 0.00% 0 CE3 Mailbox
28 0 1 0 0.00% 0.00% 0.00% 0 MIP Mailbox
29 0 1 0 0.00% 0.00% 0.00% 0 vcq_proc
30 0 1 0 0.00% 0.00% 0.00% 0 HAL Mailbox
31 0 1 0 0.00% 0.00% 0.00% 0 Mistral Reset Pr
32 0 1 0 0.00% 0.00% 0.00% 0 ECC correctable
33 0 2 0 0.00% 0.00% 0.00% 0 IP Input
34 0 18 0 0.00% 0.00% 0.00% 0 CDP Protocol
35 0 6 0 0.00% 0.00% 0.00% 0 SCP async: TCAM
36 0 1 0 0.00% 0.00% 0.00% 0 SCP async: Fake
37 4 5 800 0.00% 0.00% 0.00% 0 SCP async: RUN_C
38 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
39 0 1 0 0.00% 0.00% 0.00% 0 frr_tunnel
40 4 27 148 0.00% 0.00% 0.00% 0 IP Background
41 0 1 0 0.00% 0.00% 0.00% 0 SNMP Timers
42 0 1 0 0.00% 0.00% 0.00% 0 PPP IP Add Route
43 0 4 0 0.00% 0.00% 0.00% 0 Adj Manager
44 12 199 60 0.00% 0.00% 0.00% 0 CEF process
45 0 1 0 0.00% 0.00% 0.00% 0 IPC LC Message H
46 0 1 0 0.00% 0.00% 0.00% 0 HTTP Timer
47 36 36 1000 0.00% 0.00% 0.00% 0 SCP Hybrid proce
48 0 1 0 0.00% 0.00% 0.00% 0 TCP Timer
49 0 1 0 0.00% 0.00% 0.00% 0 TCP Protocols
50 0 1 0 0.00% 0.00% 0.00% 0 RARP Input
51 0 1 0 0.00% 0.00% 0.00% 0 Socket Timers
52 0 2 0 0.00% 0.00% 0.00% 0 DHCPD Receive
53 0 3 0 0.00% 0.00% 0.00% 0 IP Cache Ager
54 0 23 0 0.00% 0.00% 0.00% 0 SCP async: [cfg]
55 24 151 158 0.00% 0.00% 0.00% 0 SCP async: [mls]
56 4 155 25 0.00% 0.00% 0.00% 0 L3 Manager
57 0 14 0 0.00% 0.00% 0.00% 0 Feature Manager
58 0 1 0 0.00% 0.00% 0.00% 0 SCP async: HA SR
59 0 1 0 0.00% 0.00% 0.00% 0 SCP async: HA SR
60 4 2 2000 0.00% 0.00% 0.00% 0 HA SRM Master
61 4 2 2000 0.00% 0.00% 0.00% 0 HA SRM Slave
62 0 1 0 0.00% 0.00% 0.00% 0 PAD InCall
63 0 2 0 0.00% 0.00% 0.00% 0 X.25 Background
64 0 3 0 0.00% 0.00% 0.00% 0 TCP Intercept Ti
65 0 2 0 0.00% 0.00% 0.00% 0 Tag Input
66 0 43 0 0.00% 0.00% 0.00% 0 LSP Tunnel Head
67 0 2 0 0.00% 0.00% 0.00% 0 Any Transport ov
68 0 1 0 0.00% 0.00% 0.00% 0 CWAN VLAN Proces
69 0 1 0 0.00% 0.00% 0.00% 0 CWAN-RP SCP Proc
70 0 2 0 0.00% 0.00% 0.00% 0 ETH/MPLS Backgro
71 1444 1128 1280 0.00% 0.56% 0.35% 0 Exec
72 0 1 0 0.00% 0.00% 0.00% 0 Net Input
73 0 27 0 0.00% 0.00% 0.00% 0 Compute load avg
74 12 3 4000 0.08% 0.00% 0.00% 0 Per-minute Jobs
75 4 3 1333 0.00% 0.00% 0.00% 0 SCP async: Draco
77 0 2 0 0.00% 0.00% 0.00% 0 DHCPD Timer
78 0 19 0 0.00% 0.00% 0.00% 0 DHCPD Database
79 0 490 0 0.00% 0.00% 0.00% 0 CEF IPC Backgrou
80 0 1 0 0.00% 0.00% 0.00% 0 Slave Running Co
81 0 65 0 0.00% 0.00% 0.00% 0 Constellation Ba
82 0 1 0 0.00% 0.00% 0.00% 0 IPC RTTYC Messag
84 0 1 0 0.00% 0.00% 0.00% 0 SCP async: const
------------------ show controllers t1 ------------------
------------------ show controllers e1 ------------------
------------------ Mempool statistics ------------------
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 418A4DC0 91599424 11595480 80003944 79441760 79929232
I/O 7000000 16777224 3168824 13608400 13608400 13608348
------------------ show region ------------------
Region Manager:
Start End Size(b) Class Media Name
0x07000000 0x07FFFFFF 16777216 Iomem R/W iomem
0x40000000 0x46FFFFFF 117440512 Local R/W main
0x40008980 0x415A3DF6 22656119 IText R/O main:text
0x415A4000 0x41605E3F 400960 IData R/W main:data
0x41605E40 0x418A4DBF 2748288 IBss R/W main:bss
0x418A4DC0 0x46FFFFFF 91599424 Local R/W main:heap
0x80000000 0x86FFFFFF 117440512 Local R/W main:(main_k0)
0xA0000000 0xA6FFFFFF 117440512 Local R/W main:(main_k1)
------------------ show buffers ------------------
Buffer elements:
500 in free list (500 max allowed)
438 hits, 0 misses, 0 created
Public buffer pools:
Small buffers, 104 bytes (total 50, permanent 50):
50 in free list (20 min, 150 max allowed)
406 hits, 0 misses, 0 trims, 0 created
0 failures (0 no memory)
Middle buffers, 600 bytes (total 25, permanent 25):
25 in free list (10 min, 150 max allowed)
27 hits, 0 misses, 0 trims, 0 created
Big buffers, 1524 bytes (total 500, permanent 500):
500 in free list (5 min, 500 max allowed)
236 hits, 0 misses, 0 trims, 0 created
VeryBig buffers, 4520 bytes (total 10, permanent 10):
10 in free list (0 min, 100 max allowed)
0 hits, 0 misses, 0 trims, 0 created
Large buffers, 5024 bytes (total 0, permanent 0):
0 in free list (0 min, 10 max allowed)
Huge buffers, 18024 bytes (total 0, permanent 0):
0 in free list (0 min, 4 max allowed)
Interface buffer pools:
EOBC0/0 buffers, 1524 bytes (total 1200, permanent 1200):
599 in free list (0 min, 1200 max allowed)
601 hits, 0 fallbacks
600 max cache size, 88 in cache
IPC buffers, 4096 bytes (total 2, permanent 2):
1 in free list (1 min, 8 max allowed)
4 hits, 0 fallbacks, 0 trims, 0 created
Header pools:
------------------ show controllers cwan ------------------
------------------ show diagbus ------------------
MSFC-1#
00:02:10: %IPC-5-NULL: Registering Control Port Id=0x2210003, seq = 0
-Traceback= 404E380C 404E3888 40228FB4 40228FA0
MSFC-1#show bootvar
BOOT variable =
CONFIG_FILE variable does not exist
BOOTLDR variable =
MSFC-1#dir bootflash:
1 -rw- 1693168 Dec 23 2001 23:31:06 c6msfc2-boot-mz.121-8a.EX
2 -rw- 10926860 Dec 23 2001 23:31:18 c6msfc2-psv-mz.121-8a.E5
Any help would be much appreciated.
Champika
Hi prkrishn
sh run
version 12.1
no service pad
hostname MSFC-1
ip subnet-zero
interface Vlan100
no ip mroute-cache
interface Vlan101
no ip route-cache
no ip mroute-cache
interface Vlan102
no ip route-cache
no ip mroute-cache
interface Vlan103
no ip route-cache
no ip mroute-cache
interface Vlan107
no ip route-cache
no ip mroute-cache
network 155.120.0.0
auto-summary
ip classless
no ip http server
line con 0
line vty 0 4
login
end
Bridging software.
version 12.1
no service pad
hostname MSFC-1
ip subnet-zero
interface Vlan100
no ip route-cache
no ip mroute-cache
interface Vlan101
no ip route-cache
no ip mroute-cache
interface Vlan102
no ip route-cache
no ip mroute-cache
interface Vlan103
no ip route-cache
no ip mroute-cache
interface Vlan107
no ip route-cache
no ip mroute-cache
ip classless
no ip http server
line con 0
line vty 0 4
login
end
Free/Size Name
9564/12000 Init
Interface EOBC0/0
Encap type=0x1
Span encap size=0
tx_retry_error=0
MISTRAL REGISTERS:
11593764 Total
Region Manager:
Buffer elements:
Header pools:
MSFC-1#
MSFC-1#show bootvar
BOOT variable =
BOOTLDR variable =
Champika
What issues do you have with inter VLAN routing? If you have 2 MSFCs in the chassis, both the MSFCs must be configured identical and run same software version. If you have an unconfigured MSFC in slot 2, I suggest that yank out the Sup in slot 2 and test
399
