09-26-2005 09:33 AM - edited 03-03-2019 12:10 AM
I have setup 2 new vlans and their assosiated routes according to http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bf9a.shtml#topic1. I have 5 other vlans that my 2 new vlan configurations mimic (aside from obvious differences). Unfortunately I cannot get across to any other vlan from the newly defined ones, even though the config looks good and routing b/t all other vlans is still funtional. Please excuse me if I sound a little inexperienced with this b/c I unfortunately am. I was put in this situation for a "trial by fire" re-organizatioin after my old boss left. Best way to learn right?
09-26-2005 10:12 AM
How are your routes being learned? Are you using trunking? Can you paste your InterVLAN configs?
09-26-2005 10:14 AM
You'll need to post your configs to see what is wrong . Make sure both the L2 vlan definition and the layer SVI interface is created otherwise you will not be able to route between your new vlans . If you do a show vlan" do your new vlans show up and active and what port they were assigned to ????
09-26-2005 11:07 AM
Yes, if I show vlan on the Catalyst (6509) I see both new VLANs as up and active. Once connected to the router module, looking at the ip interface for one of the new VLANs this is what I see:
"Vlan10 is up, line protocol is up
Internet address is 10.1.1.3/16
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Multicast reserved groups joined: 224.0.0.9
Outgoing access list is not set
Inbound access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are never sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is disabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP Fast switching turbo vector
IP Null turbo vector
IP multicast fast switching is disabled
IP multicast distributed fast switching is disabled
IP route-cache flags are No CEF, No Distributed
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Probe proxy name replies are disabled
Policy routing is disabled
Network address translation is disabled
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
BGP Policy Mapping is disabled
IP mls switching is enabled
IP multicast multilayer switching is disabled"
This mimics most of the other funtional VLANs here.
Hardware is Cat6k RP Virtual Ethernet, address is 0030.7b92.d678 (bia 0030.7b9
2.d678)
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Last input 00:00:57, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
7308 packets input, 780228 bytes, 0 no buffer
Received 5688 broadcasts (112 IP multicast)
1926 packets output, 137574 bytes, 0 underruns
0 output errors, 4 interface resets
Your help is greatly appreciated!
09-26-2005 11:34 AM
Are these all just on the 6500 or are they trunked to lower switches ???? Think we need to se the config and how your stuff is setup .
09-26-2005 11:46 AM
These are all on the Cataylst and its Routing module. At this point there aren't any other switches or routers in the mix. Are you looking to see the router module's config or the Catalyst itself?
09-26-2005 12:47 PM
I would post the catos side , there really isn't a whole lot you have to do on the layer3 side other than create the SVI and put an address on it .
09-26-2005 01:01 PM
09-26-2005 03:21 PM
Don't see anything wrong with the catos side , only see 1 port set into vlan 10 , 6/9 so I assume that you cannot ping anything from this port to other subnets , silly question , did you set the ip address on your nic so that it falls within the vlan 10 address space and also point your default gateway at the vlan 10 SVI interface ? Unless your gateway on your nic is pointed at the SVI you won't get off that subnet.
09-27-2005 06:23 AM
Yes, I double checked as well to be sure I wasn't "fat fingering" anything. One of the things that concerns me is that I can't ping the vlan 10 SVI interface form any other vlan, but can ping the SVI of any other vlan from any other vlan. I see my previous superior setup the other interfaces as *.*.*.3, i.e:
interface Vlan100
description Root
ip address 10.10.100.3 255.255.255.0
no ip redirects
no ip route-cache
no ip mroute-cache
interface Vlan101
description Corporate
ip address 10.10.101.3 255.255.255.0
no ip redirects
no ip route-cache
no ip mroute-cache
But we use *.*.*.1 as our DG on all vlans. I am able to ping those interfaces from all vlans but 10 as well. Is this a sign that something was configured improperly?
