Intervlan routing problem dot1q
Hopefully someone out there will be able to help me with this. I have a pairs of 7204VXR and a pair of Cat 3550 SMI. I have connected port FE0/1 on each switch to one of the GE ports on each router. Each router has a seperate connection to the internet hooked into another GE interface.
I have configured the switch port as follows:
interface FastEthernet0/1
description 7204VXR scocore1
switchport trunk native vlan 101
switchport mode trunk
no ip address
This is the same for both switches. (note the switches have an etherchannel setup between them handling all VLANS. The switches have 5 VLANS configured with the routing handled by the 7204's using HSRP to failover. The config for the routers as follows:
Router 1
interface GigabitEthernet0/1
description CoreTrunk
no ip address
duplex auto
speed auto
media-type rj45
no negotiation auto
interface GigabitEthernet0/1.1
description CORE Lan
encapsulation dot1Q 101 native
ip address 62.128.192.2 255.255.255.128
standby 1 ip 62.128.192.1
standby 1 priority 10
standby 1 preempt delay minimum 120
standby 1 name COREhsrp
interface GigabitEthernet0/1.2
description S1 Lan
encapsulation dot1Q 102
ip address 62.128.192.130 255.255.255.240
standby 2 ip 62.128.192.129
standby 2 priority 10
standby 2 preempt delay minimum 120
standby 2 name S1hsrp
interface GigabitEthernet0/1.3
description MS COLO Lan
encapsulation dot1Q 103
ip address 62.128.195.2 255.255.255.192
standby 3 ip 62.128.195.1
standby 3 priority 10
standby 3 preempt delay minimum 120
standby 3 name mscolohsrp
interface GigabitEthernet0/1.4
description MISC COLO Lan
encapsulation dot1Q 104
ip address 62.128.195.66 255.255.255.192
standby 4 ip 62.128.195.65
standby 4 priority 10
standby 4 preempt delay minimum 120
standby 4 name misccolohsrp
interface GigabitEthernet0/1.5
description UNIX COLO Lan
encapsulation dot1Q 105
ip address 62.128.195.130 255.255.255.128
standby 5 ip 62.128.195.129
standby 5 priority 10
standby 5 preempt delay minimum 120
standby 5 name unixcolohsrp
interface GigabitEthernet0/3
ip address 195.97.229.206 255.255.255.252
duplex auto
speed auto
media-type rj45
no negotiation auto
Router 2 is identical except the IP's for hsrp.
If I plug a laptop into any VLAN and assign it a valid IP and gateway for that VLAN I can ping all the GE0/1.x interfaces on both routers and the virtual HSRP gateways. I can also ping the interface for GE0/3. What I cannot do is ping between two machines on different VLANS or ping from one VLAN to 195.97.229.205, which is a router at the oposite end of the /30. I can ping this from the router console.
I am at a loss as to why this is happening. Any help greatly appreciated.
Richard
  • Other Network Infrastructure Subjects
Re: Intervlan routing problem dot1q
just some ideas:
1) aren't there any ACLs involved?
2) doublecheck if the default gateway is correct ot both PCs when pinging between VLANs
3) where exactly does the tracert stop?
4) running Ethereal on the target PC, are the Ping packets coming?
Milan
What are you using to route between the subnets? Do you have static routing or a dynamic routing protocol running? If your not picky, I would enable EIGRP on them, nice and simple, very easy to use.
Can you do a "sh standby" and does it show the Active/Standby router properly for each group?
Can you hardwire the speed/duplex on the ports?
As a hint to make things easier on you. We tend to use the VLAN # as the subinterface number (and the HSRP group) if possible for each VLAN. Makes things easier to remember, ie:
instead of G0/1.1, make it
interface GigabitEthernet0/1.101
standby 101 ip 62.128.192.1
standby 101 priority 10
standby 101 preempt delay minimum 120
standby 101 name COREhsrp
just a suggestion, definitely not required...
119
