01-28-2003 07:13 AM - edited 03-02-2019 04:35 AM
I have a 6509 switch with a SupII module and MSFC. Last night I attempted to establish VLANs and routing on this switch. I logged on to the switch and created the VLANs I needed. I assigned ports to each VLAN. Then I logged on tot he MSFC and created a VLAN interface for each VLAN along with an IP address. I turned on routing and nothing worked. From what I saw, the Sup Module on ports 1/1-2 was trunking all VLANs and the MSFC on port 15/1 was turnking all VLANs. I couldn't even ping the IP address of any of the VLANs I created, so I'm missing something. I've checked sample configs and can't find what I did wrong. Any insight would be appreciated. Let me know if you need more info/details.
-Tim
01-28-2003 07:24 AM
Please make sure that the vlan interfaces on the msfcs are up. Please paste the output of sh ip interface brief or sh interface vlan # from the msfc and sh trunk from the switch
01-28-2003 07:52 AM
They are shutdown now because I had to revert everything back on the switch to VLAN 1 so the office could function today. I also had to remove the trunking on the Sup Module, but I've incluced the show trunk in case you see anything.
interface Vlan1
description MANAGEMENT
ip address 10.8.23.254 255.255.255.128
shutdown
interface Vlan20
description WORKSTATIONS and SERVERS
ip address 10.8.20.1 255.255.255.0
shutdown
interface Vlan22
description FIREWALL
ip address 10.8.22.2 255.255.255.128
shutdown
interface Vlan23
description WAN
ip address 10.8.23.2 255.255.255.128
shutdown
Console> (enable) sh trunk
* - indicates vtp domain mismatch
Port Mode Encapsulation Status Native vlan
15/1 nonegotiate isl trunking 1
Port Vlans allowed on trunk
15/1 1-1005,1025-4094
Port Vlans allowed and active in management domain
15/1
Port Vlans in spanning tree forwarding state and not pruned
15/1
01-28-2003 07:38 AM
what routing protocol are you running on the Msfc ? do you have neighbors ?
01-28-2003 07:53 AM
No nieghbors. EIGRP, although I could just as well use static routing since it's a small network.
01-28-2003 07:57 AM
what does your eigrp config look like?
01-28-2003 07:58 AM
Could you also paste the routing part of the config please ?
01-28-2003 09:47 AM
There is no routing config right now. I removed that when I reverted back. Basically it was :
router eigrp
no auto-summary
network 10.8.0.0 0.0.255.255
01-28-2003 11:37 AM
If you are talking about intervlan routing, then you don;t need any routing protocol since these vlans interface will be directly connected interfaces and routing should work. Your config seems right but here are few things that you have to make sure when you do this test next time.
First of all , all the interfaces on the msfc should be up/up which you can verify by looking at the sh interface or sh ip interface brief.
2. Second make sure you have atleast one port in that vlan is connected and working , if you are doing trunking to other switch and these vlans are forwarding then it is ok.
3. DO show ip route on the msfc and see if the routes are showing up as directly connected interfaces.
4. Capture all this that will help in determining the problem, sh interface, sh ip interface brief sh ip route, sh ver, sh arp, sh trunk, sh mod , sh test 15 from the sup
make sure you are not on the boot prompt of the msfc.. like this (router(boot)#)
01-29-2003 07:51 AM
Okay, so it's a little easier when you are setting up a trunk link between two switches because you set the port on each end to the desired trunking mode. But what are the specific steps if you are trunking between a 6509 switch and the MSFC?
I have a sup module. ports 1/1-3 (VLAN 1)
16 port gig module: ports 4/1-16 (VLAN 20)
48-port 10/10 module: ports 8/1-48 (VLAN 20, with a few ports on VLAN 23 and 21)
1 port MSFC: port 15/1(VLAN 1)
How would I configure each module so that the switch is trunking between itself and the MSFC? I think that's the step I'm missing to get this working right.
-Tim
01-29-2003 08:32 AM
By default there is the ISL trunking b/w MSFC and the sup,, As soon you define vlan interfaces on the msfc and they came up, sh trunk automatically starts showing those vlans to be forwarding. The only think you have to make sure that either there is trunk b/w two switches on which all the vlans are forwarding or atleast one active (up n working port means shows connected in show port) in each vlan to bring the vlan interface up on the msfc..
By the way what software version you are using on the sup and the msfc. Why don;t u create some dummy vlan on the sup/msfc - it should cause any problems n make sure you have something connected on that vlan and do no shut and see if that works. .
