inventory of the port settings on Cat switches
Is there a way in the LMS 2.1 to display all the ports settings (Duplex, Speed, etc) on the Cat switches?
Thanks.
Blue
Re: inventory of the port settings on Cat switches
You can use User Tracking for this.
The UT report on LMS 2.1 does not show the port settings - it only shows the port name, port status and the port number. Any other suggestions?
Thanks.
I am using LMS 2.2 so you can try this: Open Topology Services and go to your layer 2 view. Highlight the switch you want to look at, right click and select Port Attributes. This will open a new window showing you the information you are looking for. Hope this will work for you.
You can also use VLAN Port Assigment.
Choose VTP Domain to view. If you know whcih switch then clike the title to sort. Select all ports for that switch then choose from menu Reports ->Port Attributes.
Hope this helps.
89
