IOS / CATOS versions for usage with CISCO Works
what are the basic requirements for network devices so that
they can be used together with CISCO Works?
From a single release note I got the information that one should
upgrade IOS devices from11.3 or earlier to 12.0 or later.
But that's all I found. Which IOS or CatOS releases SHOULD
make sure that CISCO Works (RME, CM, ...) works correctly
with them? I'm not talking about errorfree images. I just need
a guideline which software releases SHOULD work and which
devices should be upgraded so that we don't waste our time
with SNMP debugging on old software.
Thanks in advance.
Thomas Schraml
1 REPLY
Blue
Re: IOS / CATOS versions for usage with CISCO Works
Since CiscoWorks is a suite of different applications, each application has it's own Support Device List which also contains the minimum IOS required by that particular application to work with the device. For example, if you look at: http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_3_x/3_4/dev_sup/e3_4.htm , the last column reads 'Minimum Softwarre'. This is the minimum software required by RME to work with properly.
80
