Webcast-Catalyst9k
IOS Configfuration problem
I have been trying to get my 2514 working but Im stuck. I have a 2514 connected to internet and a small lan. I can ping my outside router ip from my lan but I cant ping my outside gateway. The router is not forwarding past the outside eth0. Here is my IOS config file
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname Router
logging queue-limit 100
no logging console
enable password ####
ip subnet-zero
partition flash 2 8 8
interface Ethernet0
ip address 66.215.146.170 255.255.255.128
ip nat outside
interface Ethernet1
ip address 192.168.100.1 255.255.255.0
ip nat inside
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip nat pool ovrld 66.215.146.170 66.215.146.170 prefix-length 25
ip nat inside source list 7 pool ovrld overload
ip classless
ip route 0.0.0.0 0.0.0.0 66.215.146.129
ip http server
access-list 7 permit 192.168.100.0 0.0.0.255
line con 0
line aux 0
line vty 0 4
password ####
login
end
Re: IOS Configfuration problem
Cau u ping your 66.215.146.129 from your router?
I think 66.215.146.129 maybe down.
No I can not ping my gateway from my router. I can ping eth0 (66.215.146.170) and I have tested that I can access the internet by bypassing the router and configuring a computer directly. Does my config look correct?
HI
You are in the wrong way. If you use one IP address for translating to Global Outside , you dont need to have a Pool ip addresses and you should type this and be trusted that this is worked.
ip nat inside source list 7 interface eth0 overload
access-list 7 permit ip 192.168.100.0 0.0.0.255
NIX Technologies
Mohsen(Ir).
Ok, I have change the nat pool as you said but I still can ping my routers gateway. Here is my modified IOS config
version 12.2
hostname Router
no logging console
enable password 6314
ip subnet-zero
interface Ethernet0
ip nat outside
interface Ethernet1
ip nat inside
interface Serial0
no ip address
shutdown
interface Serial1
no ip address
shutdown
ip nat inside source list 7 interface Ethernet0 overload
ip classless
ip http server
line con 0
line aux 0
line vty 0 4
password neutec
login
end
thanks for you help and time
Hi Jay,
Make sure you do not connect the two ethernets port into one Cisco Catayst Switch. If you do so, please verify tha the SPT from the switch is disable (sometimes the SPT block one port - but make sure again there are no loop in your network when you disable SPT feature).
Best Regards,
HATO
82
