IOS for Cisco2620XM(8M Flash/32M Dram)
Hello
I have a new C2620XM with 8M flash and 32M Dram,the least requirement is to use Trunk(ISL or Dot1q).Can you give me advice on it ?I use software adversor and found the smallest DRAM is 40M.Do you Know a version can run on 32M DRAM,thank you very much
Re: IOS for Cisco2620XM(8M Flash/32M Dram)
You will need to run 12.1 to find an image that fits.
We used c2600-is-mz.121-18.
I believe the requirements for DRAM are indeed 40Mb but it runs well with 32Mb. It is an IP plus and it supports your requirements.
Are you sure that you have only 8M of flash? A new 2600-XM comes with 16M.
The image will still fit, but I was just wondering how you can have a new router with less flash than what we receive.
Leo
hello
I ever tried 12.1.14 IP plus and It can boot up but there is few memery left when I issue show proc mem.I am afraid that the system shall crash due to memery shortage.If I use in production envirment,wheather 40M dram is lease reqirement.
105
