IOS issues with AS5350
Im try to upgrade my ios from IP to IP Plus using (xmodem ?) command ater trying tftp woithout success. since then when booting it decompresses two images then finally run default sofrware. how do i get rid of all this and start afresh.
I tried deleting the bootflash and flash. see below what i see when i run show bootflash :
Router(boot)>show flash
-#- ED --type-- --crc--- -seek-- nlen -length- -----date/time------ name
1 .D image DC404C42 8F1D30 25 8854704 Jan 01 2000 00:07:55 c5350-is-mz.
121-5.XM8.bin
23126736 bytes available (8854832 bytes used)
Router(boot)>show bootflash
1 .. image C68F7FDD 28A380 18 2138880 Jan 01 2000 00:02:20 c5350-boot-m
z.0110
2 .. unknown 2CF02C0A 2AB208 25 134664 Jan 01 2000 00:02:49 crashinfo_20
000101-000249
18 .. unknown 343B0B2E 4CF7A0 25 153845 Jan 01 2000 00:20:12 crashinfo_20
000101-002012
2295904 bytes available (4519840 bytes used)
Re: IOS issues with AS5350
If you have deleted the files, you need to remove them totally out of the system using squeeze command. Also check if you still have any boot sytem commands pointing to the older images.
Check this link for more reference.
http://www.cisco.com/en/US/products/hw/univgate/ps501/products_configuration_guide_chapter09186a008007df1b.html
just an update, i have succeeded in deleting the image in the flash. But i still have about 19 crashed images in my boothflash. i have deleted/squeeced them but they still remain there. I tried using Xmodem ? command but it gives the mess " image size exceed free flash space." find below messages.
Pls i need to get rid of thism files. I believe they are eating up space.
rommon 5 > xmodem ?
Do not start the sending program yet...
File size Checksum File name
2138880 bytes (0x20a300) 0xc68f7fdd c5350-boot-mz.0110
134664 bytes (0x20e08) 0x2cf02c0a crashinfo_20000101-000249
132135 bytes (0x20427) 0x16aa76b3 crashinfo_20000101-000212
139370 bytes (0x2206a) 0x8232a6cc crashinfo_20000101-001449
132626 bytes (0x20612) 0xbac9ac57 crashinfo_20000101-000522
147162 bytes (0x23eda) 0xa47af8d1 crashinfo_20000101-000141
134055 bytes (0x20ba7) 0x81f276de crashinfo_20000101-000247
138449 bytes (0x21cd1) 0x5fe9e248 crashinfo_20000101-000228
139834 bytes (0x2223a) 0x2db0d112 crashinfo_20000101-000113
137432 bytes (0x218d8) 0xd500c84a crashinfo_20000101-000544
136121 bytes (0x213b9) 0xd3f32be0 crashinfo_20000101-000507
157896 bytes (0x268c8) 0xfd78c6b5 crashinfo_20000101-000227
133678 bytes (0x20a2e) 0x3365233f crashinfo_20000101-000851
139433 bytes (0x220a9) 0xd295b966 crashinfo_20000101-000130
142185 bytes (0x22b69) 0xe3234f8 crashinfo_20000101-000509
134790 bytes (0x20e86) 0x4761fa63 crashinfo_20000101-000722
144949 bytes (0x23635) 0x93dbbd9a crashinfo_20000101-002011
153845 bytes (0x258f5) 0x343b0b2e crashinfo_20000101-002012
156567 bytes (0x26397) 0x7b02836f crashinfo_20000101-004709
137451 bytes (0x218eb) 0xed87f963 crashinfo_20000101-015402
WARNING: All existing data in bootflash will be lost!
Invoke this application only for disaster recovery.
Do you wish to continue? y/n [n]: \y
Do you wish to continue? y/n [n]: y
Ready to receive file ? ...
BB0
ERR:Image size exceeds free flash space
rommon 6 >
Ive succeede in earsing my flash using (del/Squeeze command) i have also been able to earse bootflash with format command. The Router boots to Rommon 1 >
Im trying to load another ios with xmodem but keep getting the following (imag size to large. Fine i then decided to go with Ip only for now but get the message ( ERR:File not a valid executable)
rommon 1 > xmodem ?
130770 bytes (0x1fed2) 0x70f7172f crashinfo_20000101-000812
BB0
373
