Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
IOS update problem
Trying to upgrade 3620 router with IOS v.12
Have tftp'd successfully to flash (and erased original).
Upon reload, gone into romon mode.
At romon 1 - have issued 'confreg 0x2102' (to ensure boot instructions found in start-up config)
At romon 2 - have issued 'reset'
Getting following message: -
loadprog: error - on read during ELF program load
requested 6693080 (0x6620d8) bytes, got 2951668 (0x2d09f4)
boot: cannot load "flash:"
Have I missed anything glaring!
Thanks in advance
1 REPLY
Silver
Re: IOS update problem
A system enters the rommon mode if it is unable to find a valid image in the flash. Are you sure you loaded the correct image. Anyways, you should see if a valid image exists anywhere on your router. If none exists, you will need to use the xmodem procedure. The Xmodem procedure for the 3600 is available at
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
The normal IOS upgrade procedure for the 3600 (same as 2500) is available at
http://www.cisco.com/en/US/products/hw/routers/ps233/products_tech_note09186a00800a6744.shtml
You could also refer to 'Software Upgrade Procedure' at
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801fc986.shtml
122
