Ios upgrade problem on 7204 router
We are having problems trying to go from c7200-is-mz.120-2a to c7200-ik9s-mz.122.7a.. We are adding the following boot statement to the config:
boot system flash disk0:c7200-ik9s-mz.122-7a.
We set our config reg to 0x2002 as the router is remote and we wanted to be able to use the break key if neccessary.
When we reload we keep coming in boot mode off an IOS that appears to be in bootflash ??
Here is the console message we get:
WSR13#reload
System configuration has been modified. Save? [yes/no]: yes
Building configuration...
Proceed with reload? [confirm]
*Apr 27 14:23:35: %SYS-5-RELOAD: Reload requested
*Apr 27 14:23:36: %BGP-5-ADJCHANGE: neighbor 137.39.4.21 Down - Peer closed the
session
*Apr 27 14:23:36: %BGP-5-ADJCHANGE: neighbor 152.159.128.1 Down - Peer closed th
e session
System Bootstrap, Version 11.1(13)CA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1997 by cisco Systems, Inc.
C7200 processor with 131072 Kbytes of main memory
Self decompressing the image : #################################################
######################################################## [OK]
%SYS-4-CONFIG_NEWER: Configurations from version 12.0 may not be correctly under
stood.
%FR-5-DLCICHANGE: Interface Hssi2/0 - DLCI 500 state changed to ACTIVEboot of "c
isco2-C7200" using boot helper "bootflash:c7200-boot-mz.111-22.CC" failed
error returned: File boot failed -- File not accessible
loadprog: error - on file open
boot: cannot load "cisco2-C7200"
device does not contain a valid magic number
boot: cannot open "slot0:"
boot: cannot determine first file name on device "slot0:"
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 7200 Software (C7200-BOOT-M), Version 11.1(22)CC, EARLY DEPLOYMENT RELE
ASE SOFTWARE (fc1)
V111_22_CC_THROTTLE_BRANCH Synced to mainline version: 11.1(22)CA
Copyright (c) 1986-1998 by cisco Systems, Inc.
Compiled Mon 02-Nov-98 21:24 by jjgreen
Image text-base: 0x600088E0, data-base: 0x6036A000
cisco 7204 (NPE200) processor with 122880K/8192K bytes of memory.
R5000 processor, Implementation 35, Revision 2.1 (512KB Level 2 Cache)
Last reset from power-on
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
2 FastEthernet/IEEE 802.3 interfaces.
1 HSSI network interface.
125K bytes of non-volatile configuration memory.
4096K bytes of packet SRAM memory.
0K bytes of Flash PCMCIA card at slot 0 (Sector size 0K).
16384K bytes of Flash PCMCIA card at slot 1 (Sector size 128K).
4096K bytes of Flash internal SIMM (Sector size 256K).
Press RETURN to get started!
stood.
*Apr 27 14:27:43: %FR-5-DLCICHANGE: Interface Hssi2/0 - DLCI 500 state changed t
o ACTIVE
*Apr 27 14:27:43: %SYS-5-CONFIG_I: Configured from memory by console
*Apr 27 14:27:43: %SYS-5-RESTART: System restarted --
ASE SOFTWARE (fc1)
*Apr 27 14:27:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/
0, changed state to up
*Apr 27 14:27:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet1/
0, changed state to down
*Apr 27 14:27:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface Hssi2/0, chang
ed state to up
*Apr 27 14:27:44: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, cha
nged state to up
*Apr 27 14:27:44: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Apr 27 14:27:44: %LINK-5-CHANGED: Interface FastEthernet1/0, changed state to a
dministratively down
*Apr 27 14:27:44: %LINK-3-UPDOWN: Interface Hssi2/0, changed state to up
WARNING NOTICE
This system is restricted solely to authorized users for legitimate
business purposes only. The actual or attempted unauthorized access,
use or modification of this system is strictly prohibited. Unauthorized
users are subject to Company disciplinary proceedings and/or criminal
and civil penalties under state, federal or other applicable domestic
and foreign laws. The use of this system may be monitored and recorded
for administrative and security reasons. Anyone accessing this system
expressly consents to such monitoring and is advised that, if such
monitoring reveals possible evidence of criminal activity, may provide
the evidence of such activity to law enforcement officials. All users
must comply with Corporate Instructions regarding the protection of
information assets.
User Access Verification
Password:
*Apr 27 14:27:53: %LINEPROTO-5-UPDOWN: Line protocol on Interface Hssi2/0.1, cha
nged state to down
*Apr 27 14:27:53: %FR-5-DLCICHANGE: Interface Hssi2/0 - DLCI 500 state changed t
o INACTIVE
WSR13(boot)>sho ver
ASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 11.1(13)CA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
1)
ROM: 7200 Software (C7200-BOOT-M), Version 11.1(22)CC, EARLY DEPLOYMENT RELEASE
SOFTWARE (fc1)
WSR13 uptime is 0 minutes
System restarted by reload
1 REPLY
Re: Ios upgrade problem on 7204 router
you have a couple of errors :
1/
2/
memorydevice does not contain a valid magic numberboot: cannot open "slot0:"boot: cannot determine first file name on device "slot0:"System
So, try to format your flash and reinstall the software.
Make sure to remove all the boot system command and add the new ones.
692
