07-23-2014 07:19 AM - edited 03-03-2019 07:32 AM
I need to upgrade the IOS on our 6500s, i want to do this by using the eFSU concept. Please can someone tell me if i am able to go from the current IOS to the new one. Cisco haven't updated there SX/Y eFSU (ISSU Phase 1) Compatibility Matrix spreadsheet. I have spoke to our Cisco/maintenance support and they reckon you cant jump maintenance release numbers but according to the matrix's you can... Confused!?!
Current IOS: s2t54-ipservicesk9-mz.SPA.151-2.SY.bin
New IOS: s2t54-ipservicesk9-mz.SPA.151-2.SY3.bin
Solved! Go to Solution.
07-25-2014 04:58 AM
FSU/eFSU is beneficial if you've got VSS and/or dual supervisor (per chassis).
When FSU/eFSU works you should get minimal outage. If it doesn't your supervisors will boot one after another. This is the bit which I have witnessed in the past. Don't want to go through that again, so I use a different method but this means that the VSS pairs go down.
07-23-2014 03:40 PM
I'm not a big fan of eFSU because it doesn't seem to work for me most of the time. All my IOS upgrade with Sup720 is done the old method which has higher success rate.
07-25-2014 04:01 AM
Please can you elaborate on what doesn't work when you try using the eFSU?
07-25-2014 04:58 AM
07-25-2014 06:06 AM
Thank you for your reply, we have a 6509 running VSS with a single supervisor in each chassis. From what you have said it should run smoothly with minimal outage if any.
07-26-2014 02:06 AM
Thanks for taking the time to rate our posts.
Ok, so you have a VSS pair with a single supervisor card. Just like me and about 80% the rest of the VSS worldwide.
Bear in mind that with any single-supervisor chassis, if the supervisor reboots, the chassis becomes a piece of brick.
So when I say, minimal, you get one half of the pair operational while the other half goes down while the supervisor card reboots.
08-04-2014 06:45 AM
I successfully upgraded last week with no downtime apart from each supervisor rebooting. As everything is dual-homed there was no lose of connectivity.
Thank you for responding to my posts
05-03-2018 05:07 AM
Thanks for sharing this.
I am confused about the Cisco 6500 upgrade.
What is the difference between upgrading the VSS chassis and the IOS of the Core Switch?
Currently i have 15.1(1) SY for the Core Switch and i need to upgrade it to 15.1(2) SY. All i see the commands to upgrade it is through FSU or eFSU for IOS but what about the VSS chassis? is there any upgrade for it? How to do that in case there is?
Will really appreciate your help in this matter.
