Community Member
IP Accounting over Frame Relay sub-interface
Hi!
Does ip accounting works only over the main interface or is it able to differenciate bettween traffic for different DLCI's ?
1 REPLY
Silver
Re: IP Accounting over Frame Relay sub-interface
You can enable it under individual sub-interfaces, but the 'show ip accounting' command will show the statistics for all the interfaces together and will not identify it for each and every interface separately. You have to correlate it with the IP routing table for finding the interface.
303
