Community Member
IP addressing for Dial up clients.
I tried to set up default IP addressing for my dial up users on a 3640 router. I used a pool of three IP addresses for three lines. Things were fine till the first three users connected. A strange thing was happening after that . Users who dialed in were not getting IP addresses from the router. This happened even when all lines were free.
On debugging PPP negotiation, I got the following error -
Se3/0 IPCP: CompressType VJ 15 slots CompressSlotID (0x0206002D0F01)
Se3/0 IPCP: Address (0x030600000000)
Se3/0 IPCP: PrimaryDNS (0x810600000000)
Se3/0 IPCP: PrimaryWINS (0x820600000000)
Se3/0 IPCP: SecondaryDNS (0x830600000000)
Se3/0 IPCP: SecondaryWINS (0x840600000000)
Se3/0 IPCP: Using pool 'default'
Se3/0 IPCP: Cannot satisfy pool request
Se3/0 IPCP: Neither side knows remote address
On checking the IP pool when only one line was active, I got the message that all three IP addresses were in use. I tried using a block of 30 addresses for the pool, and things are working fine.
I had assumed that I need only three IP addresses in a pool to serve three lines. But things are not working out that way.
Any ideas ?
Re: IP addressing for Dial up clients.
Often times complex troubleshooting issues are best addressed in an interactive session with one of our trained technical assistance engineers. While other forum users may be able to help, it’s often difficult to do so for this type of issue.
To utilize the resources at our Technical Assistance Center, please visit and to open a case with one of our TAC engineers, visit
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Community Member
I do not have a CCO login to open a TAC case. Could you please try to resolve this issue for me ?
Community Member
Can you post your config?
Remote access is not my specialty, but I can try...
Somehow router still thinks that the connection on those three lines are still active and ip addresses are still in use. Type "sh users" and see is the router still see the users connected. Also "sh ip route" may report route will be there..Also post the config too.Thx..Tejal
Community Member
Hello Tejal,
The relevant portions of the sh run command are pasted below for reference.
interface Group-Async1
physical-layer async
ip unnumbered Ethernet0/1
encapsulation ppp
ip tcp header-compression passive
no ip mroute-cache
keepalive 10
async default routing
async mode dedicated
peer default ip address pool default
ppp authentication chap pap
group-range 97 100
ip local pool default
line 97 100
session-timeout 5
absolute-timeout 30
login local
modem Dialin
transport preferred none
transport input all
stopbits 1
speed 115200
flowcontrol hardware
router# #sh ip local pool
Pool Begin End Free In use
default 26 4
As already mentioned, I have only three lines connected to my router. Any help will be appreciated very much. Thanks :-)
Community Member
Pls. parse the config of pool and dial portion, you sure router is sending one of those IP addresses out of the pool? IPCP should not be
