IP connectivity problems within a VLAN
I recently configured another VLAN throughout the Campus, just like a previous 8 others, but this time the routers can not PING each other. They can ping themselves and all clients are getting the correct IP, yet they are unable to ping anything as well. The following is an example of a VLAN that IS working, and below it is a copy of the one that is NOT working:
interface Vlan101
description STU students vlan scope 2
ip address 206.00.000.253 255.255.255.0
ip helper-address 192.000.00.4
ip helper-address 192.000.00.3
no ip redirects
ip pim dense-mode
ipx network 101 encapsulation SAP
standby priority 20 preempt
standby ip 206.00.000.254
int Vlan204
description Departmental Private Computer Labs
ip address 206.00.000.252 255.255.255.0
no ip redirects
ip pim dense-mode
no shutdown
ipx network 204 encapsulation SAP
the HSRP IP's are .252 .253 standby IP of .254
Please tell me what I'm doing wrong.
bowlinm@xavier.edu
513 745-4899
Re: IP connectivity problems within a VLAN
What's happen? Is the configuration come from one L3-swtich? If so,I think there is some wrong. I suggest vlan 101 and 204 have themselves ip segments,like vlan101 has 206.0.1/24;vlan204 has 206.0.2/24.
Another things,there is something wrong with your HSRP configuration.If you configed HSRP in only one MSFC or another L3-card,it is not working.If you have redundancy engine with MSFC in one cat6k,so you enable HSRP like the below
in the first MSFC
vlan101
ip address 206.0.1.253 255.255.255.0
standby 1 ip 206.0.1.254
! default priority is 100
standby 1 preempt
standby 1 track vlan1 priority 2
standby 1 track vlan2 priority 2
standby 1 track vlanN priority 2
in the second MSFC
vlan101
ip address 206.0.1.252 255.255.255.0
standby 1 priority 99 preempt
Purple
Do the clients have their default gateway set as the standby ip address ? If for some reason they have them pointed at the non active hsrp address they won't be able to ping other addresses . The clients should be using the standby ip address as their default gateway .
110
