03-02-2004 10:59 AM - edited 03-02-2019 01:58 PM
I have some problems when a router forward DHCP requests through tunnel interface.
In the listed configuration below, all DHCP requests time out. When I configured a default route, I see DHCP requests in serial interface (not in tunnel interface).
Does anyone know if ip helper address command have priority over route-maps? Is there some workarounds to avoid this behavior?
TIA
Jefferson Soletti
Current configuration:
! Last configuration change at 14:36:06 BRA Tue Mar 2 2004 by oper
version 11.3
ip subnet-zero
no ip domain-lookup
interface Tunnel101
ip unnumbered Ethernet0
bandwidth 256
tunnel source Serial0
tunnel destination 10.4.3.29
interface Ethernet0
ip address 172.19.0.1 255.255.255.224
ip helper-address 172.20.1.100
no ip directed-broadcast
ip policy route-map test1
interface Serial0
ip address 10.101.32.2 255.255.240.0
bandwidth 256
router eigrp 1
network 10.0.0.0
ip classless
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
ip route 172.19.0.0 255.255.255.224 Tunnel101
access-list 101 permit ip any 172.19.0.0 0.0.0.31
access-list 102 permit ip any any
route-map test1 permit 10
match ip address 101
set interface Ethernet0
route-map test1 permit 11
match ip address 102
set interface Tunnel101
03-02-2004 11:28 AM
What's happening is the broadcast packet is being picked up and being processed by the helper code, which sets the next hop to 172.20.1.100. The resulting packet is then switched; since there is PBR on the interface, the policy is examined first, and the policy tells the packet to be switched out Tunnel 101. Or at least that's what I would expect.
At this point, though, I'm not certain what the problem is. Are you saying the packets will not be switched out the tunnel interface at all? They are being switched out the serial interface, but isn't that where the tunnel interface would live?
Why are you running policy based routing here anyway? The only policies you have set up are for specific destinations to be routed a specific way, and that can be handled using standard static routes, so I'm not certain what your final goal is....
Russ.W
03-03-2004 06:46 AM
Yes. Only DHCP packets are switched out the serial interface without GRE encapsulation. Normal IP traffic are switched out tunnel 101.
I can see these DHCP packets (with dest. 172.20.1.100) "traveling" in network 10.0.0.0
These packets should be encapsulated as others IP packets (like ICMP) and should be routed through network 10.0.0.0.
I'm running policy based just for migration scenario. I configured the route-map to ip any any to be sure that this is not the problem. And, also, I need to be sure that this model (helper address, tunnel and route-maps) works.
I think that describe my problem better.
TIA
Jefferson Soletti
03-02-2004 12:09 PM
Do you have a route for your tunnel destination IP? Is your tunnel up?
03-03-2004 06:49 AM
Yes and yes.
Like I said in reply before, normal IP traffic are working fine. Just DHCP relay doesn't work.
TIA,
Jefferson Soletti
