Ip helper address with Policy Base Routing
Does ip helper work with Policy Base Routing? and if so how and what version of the router software do you need?
thanks
Blue
Re: Ip helper address with Policy Base Routing
so long as the policy allows for bootp/dhcp to be forwarded, then ip helper should work as normal.
Thanks, that is what I was missing.. added to the access-list works fine..
As first function at the ingress interface is ip_helper, as second function at the same ingress interface is policy-based-routing.
We have the same situation regarding ip nat in combination with policy-based-routing.
153
