IP Phone and Data Port on the same Ethernet
Would need some advise on how can I configure Voice vlan and data vlan on
Cisco C3524XL Switch With the IOS Version(C3500XL-C3H2S-M), Version 12.0(5)WC13, RELEASE SOFTWARE (fc1)
I would like to configure it to work on IP Phone n data on the same ethernet port.
same of the configuation
interface FastEthernet0/23
switchport access vlan 200
switchport voice vlan 190
spanning-tree portfast
Mc
Re: IP Phone and Data Port on the same Ethernet
Hi Friend,
The config is perfect if it is a cisco ip phones or infact any ip phone which understand voice vlan because if you configure this command it will automatically form an internal trunk and allow both the vlans to pass but incase the ip phone does not understand voice vlan then you need to manually confugure trunk port also on the switchport.
Ankur
can U advise how to trunk ? I have turnk the uplink port. Hmmmm blur...
Append with the vlan db .
VLAN Name Status Ports
1 default active Fa0/17, Fa0/18, Fa0/19, Fa0/20,
Fa0/21, Fa0/24, Gi0/1
190 HQ190-IPPhone active Fa0/22
200 HQ200 active Fa0/23
interface GigabitEthernet0/2
switchport trunk allowed vlan 1,100,190,200,300,1002-1005
switchport mode trunk
Your config is right.You have to simple use the command:
conf t
int gig 0/x
switchport voice vlan <--- Define the voice vlan here in the port.
If you want to allow specific vlans between the switches you should use the command as you has used using " switch port allowed " , make sure that voice vlan and date vlan both are passed on the
trunk.If you want you can pass only the voice vlan and data vlan on teh switchport connecting the IP phones.
In my experience you should always use trunk configuration on the ports connecting the IP phones with 3500XL's the other config doesnot work most of the times.
regards,
-amit singh
Thank s fro yout help,
Would appreicate you can show me your sample configuration. as I tried you advise. I doubt it works
The sample show below is fs0/24 which is connected to user ip phone and data port .
Whereas the Gi0/2 is the uplink to our aceess switches,,
interface FastEthernet0/24
switchport trunk allowed vlan 1,200,1002-1005
We use this config a lot with our phones.
int fa0/1
description CISCO PHONE
switchport trunk native vlan 2
switchport voice vlan 3
no ip address
no snmp trap link-status
We do not use VLAN 1 (native vlan) for any regular traffic. Our data vlan is 2 and voice vlan is 3. In order for a computer to get it's IP (assuming their DHCP works correctly for that VLAN) is to make sure the native vlan vlan-number is in each port config. This way everything defaults out the "data" vlan while voice only comes out the "voice" vlan.
Hmmm
can U sh vlsn , ,mine did not display the port fa0/21 which I copy n paste the command line given
interface FastEthernet0/21
switchport trunk native vlan 200
200 HQ200 active Fa0/1, Fa0/2, Fa0/3, Fa0/4,
Fa0/5, Fa0/6, Fa0/7, Fa0/8,
Fa0/9, Fa0/10, Fa0/11, Fa0/12,
Fa0/13, Fa0/14, Fa0/15, Fa0/16,
Fa0/23
thanks guys, It works..
Mc
MC,
Update us with your final port config and also any special thing you did.
regards
-amit singh
This is the cmd line that works....
Hmmm. It work on one of ip phone but no the other..
any thought
really Puzzle
Thanks guys...
325
