Community Member
IP Route for a serial point to point connection
I have 2 2610 connected to a serial point to point link but I can't get them to ping the serial or ethernet. Here iCurrent configuration:
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname 1
enable secret xxxxx
clock timezone EST -4
ip subnet-zero
ip host shoppes 130.106.100.15
interface Ethernet0/0
ip address 130.100.100.16 255.255.0.0
interface Serial0/0
ip address 192.100.100.16 255.255.0.0
service-module t1 clock source internal
service-module t1 timeslots 1-8
router eigrp 10
redistribute connected
redistribute static
network 130.100.0.0
network 130.106.0.0
network 192.100.0.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 130.100.100.10
ip route 130.106.0.0 255.255.0.0 192.100.100.15
no ip http server
line con 0
s the sh run
Silver
Re: IP Route for a serial point to point connection
the ehternet & serial on what router ? what does the config on the other side look like?
Can you also paste in a sh int from all 4 interfaces the 2 serials and 2 ethernets
Community Member
The default route shows pointing to ethernet interface. Default route should point to the serial IP address of other end.
Bronze
You are not running EIGRP on the serial link. The statement "network 192.100.0.0" under EIGRP covers only the class C network 192.100.0.0, and 192.100.100.0/16 is not included in this.
Mark
255
