IP Routing Problem
Could someone please help me figure out why routing is not working on the ESwithes with in the LAN?
The WAN routing works fine.
I actually have 2 3550 and 1 2950 but if I can figure out the one 3550 I can fix the other two.
!1751 Router
version 12.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
logging queue-limit 100
logging buffered 51200 debugging
logging console critical
memory-size iomem 25
ip subnet-zero
no ip source-route
no ip rcmd domain-lookup
ip tcp synwait-time 10
ip name-server
ip name-server
no ip bootp server
ip cef
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 netshow
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 smtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip inspect name DEFAULT100 icmp
ip audit notify log
ip audit po max-events 100
ip ssh time-out 60
ip ssh authentication-retries 2
interface Loopback0
no ip address
interface ATM0/0
no ip address
ip route-cache flow
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 1
interface FastEthernet0/0
description $FW_INSIDE$$ETH-LAN$
no ip address
ip access-group 100 in
ip mtu 1452
ip nat inside
ip route-cache flow
ip tcp adjust-mss 1452
speed auto
no cdp enable
interface FastEthernet0/0.1
description VLAN 1 Interface
encapsulation dot1q VLAN 1
ip address 192.168.9.59 255.255.255.192
interface FastEthernet0/0.2
description VLAN 2 Interface
encapsulation dot1q VLAN 2
ip address 192.168.9.126 255.255.255.192
interface FastEthernet0/0.3
description VLAN 3 Interface
encapsulation dot1q VLAN 3
ip address 192.168.9.190 255.255.255.192
interface FastEthernet0/0.4
description VLAN 4 Interface
encapsulation dot1q VLAN 4
ip address 192.168.9.254 255.255.255.192
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip access-group 101 in
ip mtu 1452
ip nat outside
ip inspect DEFAULT100 out
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication pap callin
ppp pap sent-username
ip nat inside source list 7 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
logging trap debugging
access-list 7 permit 192.168.0.0 0.0.255.255
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 192.168.9.0 0.0.0.255 any
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any log
access-list 102 remark Restrict Web Access
access-list 102 remark SDM_ACL Category=1
access-list 102 permit ip 192.168.11.0 0.0.0.255 host 12.155.193.32
access-list 102 remark my.screenname.aol.com
access-list 102 deny ip 192.168.10.0 0.0.0.255 host 64.12.151.141
access-list 102 remark login.passport.net
access-list 102 deny ip 192.168.10.0 0.0.0.255 host 65.54.229.246
access-list 102 remark messenger.yahoo.com
access-list 102 deny ip 192.168.10.0 0.0.0.255 host 66.163.172.51
access-list 102 remark www.aol.com
access-list 102 deny ip 192.168.10.0 0.0.0.255 host 205.188.145.214
access-list 102 remark my.msn.com
access-list 102 deny ip 192.168.10.0 0.0.0.255 host 207.68.171.254
access-list 102 remark www.mymsn.com
access-list 102 deny ip 192.168.10.0 0.0.0.255 host 207.68.172.254
access-list 102 remark www.msn.com
access-list 102 deny ip 192.168.10.0 0.0.0.255 host 207.68.173.244
access-list 102 remark www.hotmail.com
access-list 102 deny ip 192.168.10.0 0.0.0.255 host 207.68.173.245
access-list 102 remark www.yahoo.com
access-list 102 deny ip 192.168.10.0 0.0.0.255 host 216.109.118.65
access-list 102 remark mail.yahoo.com
access-list 102 deny ip 192.168.10.0 0.0.0.255 host 216.109.127.60
access-list 102 permit ip 192.168.10.0 0.0.0.255 any
access-list 102 permit ip 192.168.9.0 0.0.0.255 any
access-list 102 deny ip any any
access-list 103 remark Mac IN Access
access-list 103 remark SDM_ACL Category=1
access-list 103 permit ip host 192.168.9.87 any
dialer-list 1 protocol ip permit
no cdp run
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!
^C
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 4000 1000
scheduler interval 500
end
!3550 ESwitch
version 12.1
no service single-slot-reload-enable
no service pad
service timestamps debug uptime
service timestamps log uptime
clock timezone MDT 6
ip subnet-zero
ip routing
cluster enable
cluster member 1 mac-address
cluster member 2 mac-address
interface FastEthernet0/1
switchport access vlan 3
switchport mode access
no ip address
duplex full
speed 100
spanning-tree portfast trunk
interface FastEthernet0/2
no ip address
duplex half
speed 10
interface FastEthernet0/3
no ip address
duplex full
speed 100
interface FastEthernet0/4
no ip address
duplex full
speed 100
interface FastEthernet0/5
switchport access vlan 4
no ip address
duplex full
speed 100
interface FastEthernet0/6
no ip address
duplex full
speed 100
interface FastEthernet0/7
no ip address
duplex full
speed 100
interface FastEthernet0/8
no ip address
duplex half
speed 10
interface FastEthernet0/9
no ip address
duplex half
speed 10
interface FastEthernet0/10
no ip address
interface FastEthernet0/11
no ip address
interface FastEthernet0/12
switchport access vlan 2
no ip address
interface FastEthernet0/13
no ip address
interface FastEthernet0/14
no ip address
interface FastEthernet0/15
no ip address
interface FastEthernet0/16
no ip address
duplex full
speed 100
interface FastEthernet0/17
no ip address
duplex full
speed 100
interface FastEthernet0/18
no ip address
interface FastEthernet0/19
no ip address
duplex full
speed 100
interface FastEthernet0/20
no ip address
duplex half
speed 10
interface FastEthernet0/21
no ip address
duplex full
speed 100
interface FastEthernet0/22
no ip address
interface FastEthernet0/23
no ip address
interface FastEthernet0/24
no ip address
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
switchport mode trunk
no ip address
interface Vlan1
ip address 192.168.9.58 255.255.255.192
interface Vlan2
ip address 192.168.9.125 255.255.255.192
interface Vlan3
ip address 192.168.9.189 255.255.255.192
interface Vlan4
ip address 192.168.9.253 255.255.255.192
router rip
redistribute connected
network 192.168.9.0
ip classless
ip http server
ip route 0.0.0.0 0.0.0.0 192.168.9.1
ip access-list extended CMP-NAT-ACL
dynamic Cluster-HSRP deny ip any any
dynamic Cluster-NAT permit ip any any
line con 0
line vty 0 4
password
login
line vty 5 15
password
login
end
Bronze
Re: IP Routing Problem
From your config, it looks like you have internal hosts connected to your fast ethernet interface that need to be translated to a routeable address to have internet access out the dialer interface. If the problem is, your internal 192.168.x.x hosts aren't getting out to the internet, try moving the command "ip nat inside" under the subinerfaces instead of the main interface.
ip nat inside
ip nat inside
ip nat inside
ip nat inside
You will also want to move the ip access-group 100 in command to each subinterface you want to filter traffic on. Hope that helps.
This solves the internet routing problems from the VLANs to the internet but does not solve the VLAN to VLAN routing on the switches. On the same switch I can not see between VLANs.
117
