Webcast-Catalyst9k
Ip to port location
I have 2950 switches. There is an suspicious ip address on my network that I would like to track down. Is there a way to look at the switching tables and determine what port a specific IP address is connected to?
Thanks!
1 ACCEPTED SOLUTION
Re: Ip to port location
ok first your gonna need the MAC address of the device as the 2950 is Layer 2 device. To do this ping the suspect IP address and check the arp table, To do this in windows issue an "arp -a" from a command prompt.
Once you have the MAC address you can then check out the MAC swithcing table on the switch with
show mac-address-table
or even
show mac-address-table | inc XXXX.YYYY.ZZZZ
or
show mac-address-table address XXXX.YYYY.ZZZZ
depending on IOS version. This will show you which port this mac is associated with.
HTH,
ACW.
or even
or
HTH,
ACW.
Thanks for the reply. Worked great and found the machine.
http://kb.packetpros.com/kb.asp?a=show&ID=16
I can't post the actual, it's too big.
116
