IP UNNUMBERED ON WAN DOES NOT WORK PROPERLY ......
giuliano
I have 4 leased line with 4 cisco 2610 with 2 serial.
Encapsulation HDLC, load balancing with EIGRP and failover with MHRSP.
I configured my serials interfaces with ip unnumbered e0/0, so each s0/x obtain ip address from interface ethernet 0/0.
But when i ping a router from another, it fail.
From local network i reach ethernet interface of local router, but not ethernet of other routers.
Why this? I'm missing somethings?
Thanks.
j-bliss
Remember you can't ping an IP unnumbered interface.
faheyd
Well, first start with troubleshooting your serial interfaces to make sure you have connectivity between your routers:
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1915.htm
Next, troubleshoot your routing protocol:
http://www.cisco.com/warp/public/105/top_issues/iprouting/top_issues_rp.shtml
True, you can't ping your serial I/F, but you should be able to ping eth0 to eth0 on your routers.
Have fun!!
