Community Member
IPM data migration to another system
I've currently IPM v2.4 running on a Solaris server. Now I need to move this configuration to a more performant server. So I installed everything on this new server. But how to move the all IPM data from the old to the new system?
The documentation indicates there's an automatic backup every night and how to start the restore procedure (./ipm dbrestore) but doesn't indicate which files are necessary for the restore and where these are/should be located.
Other resources are saying you need to copy the original db-files, IPMDB.db, IPMDB.log, ipm.env and .dbpassword.
Very confusing.
Blue
Re: IPM data migration to another system
Just to clarify, your one server is running IPM 2.4 and the other new server is also running the same v2.4 on Solaris?
Blue
On the Solaris box: /opt/CSCOipm/bin/ipm dbbackup
This will create the backup files in: /opt/CSCOcwbS/db/CSCOipm/backup
Then copy those files to the same directory on your other Solaris server, it should be something like:
$NMSROOT\CSCOcwbS\db\CSCOipm\backup
Then on the other box, run: $NMSROOT\CSCOipm\bin\ipm dbrestore
All your sources, targets, collectors are in: /opt/CSCOipm/etc
You may want to copy those files in case the database does not have them. Hope this helps.
Community Member
Indeed both systems are running IPM v2.4.1.
Thanks for the help.
rgds, Geert.
82
