Webcast-Catalyst9k
IPSEc not working with VTI interface
Dear All,
  I had tried IPsec with fast Ethernet 0/1 it works fine but when i tried to map same ipsec crypto to tunnel1 {VTI} interface IPsec not working.
 My remote Site checks for source IP of fast Ethernet 0/0 {Proxy ID in Juniper}
 I tried to MAP crypto map to tunnel 1 interface but it not work
 below here is my config {Peer IP, Pre-Shared Key, Names removed for security}
PuTTY log 2014.06.26 16:46:48
sh run
Building configuration...
Current configuration : 1556 bytes
version 12.4
hostname xyz
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username xyz password 0 xyz
crypto isakmp policy 1
 encr 3des
 authentication pre-share
group 5
crypto isakmp key MYKEY@123 address XX.XX.XX.XX
crypto ipsec transform-set ABC esp-3des esp-sha-hmac
crypto ipsec profile Tunnel
crypto ipsec profile tunnel
  set transform-set ABC
set pfs group5
crypto map ABC 1 ipsec-isakmp
set peer XX.XX.XX.XX
match address 108
 interface Tunnel1
 description Branch_End
ip unnumbered FastEthernet0/1
 tunnel source FastEthernet0/1
 tunnel destination XX.XX.XX.XX
  tunnel mode ipsec ipv4
 tunnel protection ipsec profile tunnel
 interface FastEthernet0/0
 description LAN
 ip address 10.1.10.1 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.1.2 255.255.255.0
 duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
 clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
 clock rate 2000000
 ip forward-protocol nd
 ip route 0.0.0.0 0.0.0.0 Tunnel1
ip http server
no ip http secure-server
 access-list 108 permit ip 10.1.10.0 0.0.0.255 any
control-plane
 line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
 end
MYROUTER#
MYROUTER#sh crypto session
Crypto session current status
Interface: tunnel 1
Session status: DOWN-NEGOTIATING
Peer: XX.XX.XX.XX port 500
  IKE SA: local 192.168.1.2/4500 remote 223.30.69.138/4500 Active
  IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
        Active SAs: 2, origin: crypto map
MYROUTER#
 Because of  IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0 IPsec not up Remote Device checks for IPSEC FLOW: permit ip 10.1.10.0/255.255.255.0 0.0.0.0/0.0.0.0
 Please help me thanks in advance.
Hemant
Hi Hemant,Can you put a
Hi Hemant,
Can you put a  route to the tunnel destination and see if it helps.
Best Regards,
Bheem
Crypto map not needed, if you
Crypto map not needed, if you use ipsec vti. Need only crypto ipsec profile.
Try without crypto map.
158
