Ipsec over Frame Relay
Does it possible to use IPSec over Frame Relay?
I don't see problem but it's better to ask...
routerIOS/VPN----Frame Relay---routerIOS/VPN
Best Regards
A.Calligher
Bronze
Re: Ipsec over Frame Relay
Yes.
Definitely you can configure it over frame-relay.
If its a private cloud, you really dont need to configure encryption over the cloud between two sites. But if you are worried about somebody from the service provider end, trying to hack, and security is of prime importance, then definitely, its recommended, to run IPSEC between the sites.
258
