IPSEC running over ISDN PRI PPP Multilink
DEar All
I have a 3640 with a PRI module that I use for backing up my Frame relay network. I have also the need in case of DR to connect the PRI 30 Channel to a DR site and run IPSEC over the top. I have problem running IPSEC once my PPP Multilink add new channel the IPSEC connectivity grounds to a halt.
At my DR site I have a 2620, I have a VPN module at both ends.
Does someone have a sample config that they have tested.
Yves
1 REPLY
Re: IPSEC running over ISDN PRI PPP Multilink
IPsec is sensitive to out of order packets. This is the most likely explanation for your issue. Please check the following techdoc for a workaround:
http://googleweb-1.cisco.com/search?q=cache:http://cco-rtp-1.cisco.com/en/US/partner/tech/tk175/tk15/technologies_configuration_example09186a0080093e52.shtml+ppp+multilink+ipsec&ie=UTF-8&site=CDC&output=xml_no_dtd&client=CDC&proxystylesheet=CDC&oe=UT...
I believe the solution might be in the configuration of :
-no ppp multilink fragmentation- as described.
Let me know if this helps.
Leo
144
