08-05-2003 02:39 AM - edited 03-02-2019 09:21 AM
Dear all
I have set up the center router for hub (R1) and want to connect a few shops using the ipsec tunnel. All the shop are different segment. Are they communicating with each others.
Shop1-------> Center R1 <---------Shop2
10.2.1.x 10.2.0.x 10.2.2.x
Can Shop1 communicate with Shop2?
Please advice. Thanks
Godwin
08-21-2003 03:46 AM
Are you doing a simple ping (this will use the WAN interface's address as source) or an extended ping (with a source IP address in the range used for the VPN)?
08-21-2003 05:25 PM
Yes, I have.
08-21-2003 10:55 PM
Sorry but I don't know how to interpret your answer. Have you tried a simple ping OR have you tried an extended ping?
