IPv6 Extention Headers - Need test programs
All,
I would like to know if anyone has tested various different IPv6 extension headers with any IPv6 test programs.
The MS ping6.exe has an option -r which enables the routing header extension, but would like to see more of the options being used as I am evaluating IPv6 in a very small way :)
Kind regards,
Ken
Silver
Re: IPv6 Extention Headers - Need test programs
What is the exact requirement of this ipv6 extension header and test programs in your application.If your need can be mentioned,then it will aid me in providing u with some more relevant options instead of flooding u with all informations.
Sam,
Thx for the help,
I would just like to be able to generate the following extenstion headers from a router (say extended ping) or a test program so I can see the use of the speficic headers and how they influence IPv6 in our lab environment.
Out of the following
Hop-by-Hop Options header
Destination Options header
Routing header
Fragment header
Authentication header and Encapsulating Security Payload header
Upper-Layer header
The only one I can seem to generate is the router header from windows XP ping6.exe
Please exuse the IPv6 address
Frame 8 (118 bytes on wire, 118 bytes captured)
Arrival Time: Oct 26, 2005 09:53:25.309521000
Time delta from previous packet: 0.000028000 seconds
Time since reference or first frame: 5.340757000 seconds
Frame Number: 8
Packet Length: 118 bytes
Capture Length: 118 bytes
Protocols in frame: eth:ipv6:icmpv6:data
Ethernet II, Src: Cisco_9c:6a:12 (00:0e:83:9c:6a:12), Dst: CompaqCo_34:00:25 (00:02:a5:34:00:25)
Destination: CompaqCo_34:00:25 (00:02:a5:34:00:25)
Source: Cisco_9c:6a:12 (00:0e:83:9c:6a:12)
Type: IPv6 (0x86dd)
Internet Protocol Version 6
Version: 6
Traffic class: 0x00
Flowlabel: 0x00000
Payload length: 64
Next header: IPv6 routing (0x2b)
Hop limit: 63
Source address: 2222:2222:2222:2222:2222:2222:2222:2223
Destination address: 2222:2222:2222:2222:2222:2222:2222:2223
Routing Header, Type 0
Next header: ICMPv6 (0x3a)
Length: 2 (24 bytes)
Type: 0
Segments left: 0
address 0: 2222:2222:2222:2222:2222:2222:2222:2222
Internet Control Message Protocol v6
Type: 128 (Echo request)
Code: 0
Checksum: 0xb1e2 [correct]
Sequence: 0x00f3
Data (32 bytes)
0000 00 02 a5 34 00 25 00 0e 83 9c 6a 12 86 dd 60 00 ...4.%....j...`.
0010 00 00 00 40 2b 3f 22 22 22 22 22 22 22 22 22 22 ...@+?""""""""""
0020 22 22 22 22 22 23 22 22 22 22 22 22 22 22 22 22 """""#""""""""""
0030 22 22 22 22 22 23 3a 02 00 00 00 00 00 00 22 22 """""#:.......""
0040 22 22 22 22 22 22 22 22 22 22 22 22 22 22 80 00 """"""""""""""..
0050 b1 e2 00 00 00 f3 61 62 63 64 65 66 67 68 69 6a ......abcdefghij
0060 6b 6c 6d 6e 6f 70 71 72 73 74 75 76 77 61 62 63 klmnopqrstuvwabc
0070 64 65 66 67 68 69 defghi
This is purley for evaluation purposes and is not a system issue as such.
If there is an IPv6 test executable that can tell the IPv6 stack to utilise certain IPv6 options (thus using various extention headers) that would help me in my quest.
Kind regards and many thx,
Ken
185
