Webcast-Catalyst9k
Ipv6 routing rip
Tryin to setup a ipv6 testlab with 2 cisco3600 routers(1serial,2ethernet) connected with 2 serial cables with 2 hosts on each side of network.
Assigned ipv6 addresses to all needed interfaces and on both sides all works wel exept the rip routing proces.(The basic setup works cause last week i did same setup with ipv4 and it worked fine.)
When working with ipv4 it was needed to add a route with the network command but where did it go in ipv6?
i enable a routing rip proces on the ethernet and serial interfaces but when i do a sh ipv6 routing rip no routes show up.All protocols and lines are up but i canot seems to go to the other side of the network.Any help would be appricited.txs.
Re: Ipv6 routing rip
The way to configure RIP under ipv6 is a bit different than under ipv4. You have to enable RIPv6 on a per interfaces basis in the following way.
int e0/0
ipv6 rip TEST enable
ipv6 router rip test
Do a "sh ipv6 rip" to see if RIPv6 has been interface on your all the desired interfaces.
Hope this helps,
Harold Ritter
Sr. Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
I meant "if RIPv6 has been enabled on all the desired interfaces"
I haven't had my first coffee yet ;o)
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Anonymous
N/A
If i do a sh ipv6 rip it sais that its enablede on both interfaces (fastethernet & serial) ut that doesn't mean it works.. i have no connection to the other network.
Serial0/0 on router0:global uicast addres: 2001:b78::a1:b2:c3:1/32
serial 2/0 on router2:
2001:b78::a1:b2:c3:2/32
I can ping both serial interfaces from the console of the routers but if i try to ping beyond serial aka ethernet it wont go thru.. weird..If i look into the manuals its a piece of cake but i didn't had cake yet :) ... any other ideas?I'll try to post my run 2 night.
Txs
Please post your configs and IOS version used.
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Anonymous
N/A
Router01 :
Building configuration...
Current configuration : 908 bytes
version 12.2
hostname router01
enable password secret
ip subnet-zero
ipv6 unicast-routing
mta receive maximum-recipients 0
interface FastEthernet0/0
no ip address
duplex auto
speed 100
ipv6 address 3FFE:C00:C18:C1::/64 eui-64
ipv6 enable
ipv6 rip ipsix enable
ipv6 rip ipsix default-information originate
interface Serial0/0
bandwidth 100000
no ip address
ipv6 address 2001:B78::A1:B2:C3:1/32
clockrate 8000000
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip classless
ip http server
ipv6 router rip ipsix
ipv6 router rip ipxsix
call rsvp-sync
mgcp profile default
dial-peer cor custom
line con 0
line aux 0
line vty 0 4
password secret
login
end
router01#sh ver
router01#sh version
IOS (tm) 3600 Software (C3640-IK9S-M), Version 12.2(13)T5, RELEASE SOFTWARE (fc
1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Wed 28-May-03 13:34 by nmasa
Image text-base: 0x60008930, data-base: 0x61BAC000
ROM: System Bootstrap, Version 11.1(20)AA1, EARLY DEPLOYMENT RELEASE SOFTWARE (f
c1)
router01 uptime is 1 minute
System image file is "flash:c3640-ik9s-mz.122-13.T5.bin"
cisco 3640 (R4700) processor (revision 0x00) with 125952K/5120K bytes of memory.
Processor board ID 12906882
R4700 CPU at 100Mhz, Implementation 33, Rev 1.0
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
2 FastEthernet/IEEE 802.3 interface(s)
1 Serial network interface(s)
DRAM configuration is 64 bits wide with parity disabled.
125K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
16384K bytes of processor board PCMCIA Slot1 flash (Read/Write)
router01#
router01#sh ipv
router01#sh ipv6 RIP
RIP process "ipsix", port 521, multicast-group FF02::9, pid 127
Administrative distance is 120. Maximum paths is 16
Updates every 30 seconds, expire after 180
Holddown lasts 0 seconds, garbage collect after 120
Split horizon is on; poison reverse is off
Default routes are generated
Periodic updates 5, trigger updates 1
Interfaces:
Serial0/0
FastEthernet0/0
Redistribution:
None
router01#sh ipv6 route rip
IPv6 Routing Table - 6 entries
Codes: C - Connected, L - Local, S - Static, R - RIP, B - BGP
U - Per-user Static route
I1 - ISIS L1, I2 - ISIS L2, IA - ISIS interarea
router01#
Anonymous
N/A
Router02:
Current configuration : 861 bytes
version 12.2
hostname rout
enable password supersecret
ip subnet-zero
interface FastEthernet2/0
no ip address
shutdown
duplex auto
speed auto
interface Serial2/0
no ip address
ipv6 address 2001:B78::A1:B2:C3:2/32
ipv6 enable
no fair-queue
interface FastEthernet2/1
no ip address
duplex auto
speed auto
ipv6 enable
ip classless
ip http server
ipv6 router rip
call rsvp-sync
line con 0
password xxx
line aux 0
line vty 0 4
password xxxx
login
end
Anonymous
N/A
and to end it all :)
router02#
router02#sh interfaces serial 2/0
Serial2/0 is up, line protocol is up
Hardware is DSCC4 Serial
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input 00:00:03, output 00:00:02, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
73 packets input, 6016 bytes, 0 no buffer
Received 72 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
73 packets output, 6016 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
2 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
router02#sh ver
1)
c1)
router02 uptime is 7 minutes
Processor board ID 12409883
Bridging software.
16384K bytes of processor board PCMCIA Slot0 flash (Read/Write)
router02#sh ipv
router02#sh ipv6 rip
Default routes are not generated
Periodic updates 18, trigger updates 1
Interfaces:
FastEthernet2/1
Serial2/0
Redistribution:
None
thanks.
You configured the same prefix (3FFE:C00:C18:C1::/64 ) on both LAN interfaces. RIPv6 advertises the prefix from one side to the other but it is not installed on the receiving router because of the connected route for that prefix. Try configuring 3FFE:C00:C18:C2::/64 on router02. This should fix it.
Hope this helps,
Harold Ritter
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
135
