You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
IPX GRE Tunnel and Netware & EIGRP errors
I've got a GRE tunnel setup between two sites. At either site PIX firewalls connect to the carrier IP network and I have a 2611 infront of the PIX (at both ends). The 2611 is doing the GRE tunnel and is configured as a "one armed tunnel router". That is PIX and 2611 are connected to corporate LAN together (parallel) and not is series. The second ethernet interface on the 2611 is shutdown.
The issue I have is that some IPX clients get BTRIEVE errors at random. There are no problems reported with IP between the sites. A ping with large payload shows no packet loss and RTT of about 13 ms.
Prior to this we has a WAN link between the site and was routing IP/IPX and everything worked fine.
Here is the config of the first 2611
interface Tunnel0
no ip address
ipx network BCBB000A
ipx hello-interval eigrp 100 10
ipx hold-down eigrp 100 60
tunnel source Ethernet0/0
tunnel destination 172.16.32.10
interface Ethernet0/0
ip address 151.123.123.4 255.255.0.0
half-duplex
ipx network 10056D7C encapsulation SAP
ipx network 6356555 encapsulation NOVELL-ETHER secondary
ipx router eigrp 100
network all
and the second 2611 is:
interface Tunnel0
no ip address
ipx hold-time eigrp 100 10
tunnel destination 151.123.123.4
ip address 172.16.32.10 255.255.240.0
half-duplex
ipx network 2
network all
The other funny thing is that if I try and using IPX EIGRP, the neighbour adjacency keeps flapping. Here is the debug eigrp trace from the router:
00:19:30: %DUAL-5-NBRCHANGE: IPX-EIGRP 100: Neighbor BCBB000A.000a.b7ca.f280 (Tu
nnel0) is up: new adjacency
00:19:35: %DUAL-5-NBRCHANGE: IPX-EIGRP 100: Neighbor BCBB000A.000a.b7ca.f280 (Tu
nnel0) is down: peer restarted
00:19:35: EIGRP: Neighbor BCBB000A.000a.b7ca.f280 went down on Tunnel0
00:19:35: EIGRP: New peer BCBB000A.000a.b7ca.f280
00:19:44: %DUAL-5-NBRCHANGE: IPX-EIGRP 100: Neighbor BCBB000A.000a.b7ca.f280 (Tu
00:19:44: EIGRP: Neighbor BCBB000A.000a.b7ca.f280 went down on Tunnel0
00:19:45: EIGRP: New peer BCBB000A.000a.b7ca.f280
00:19:45: %DUAL-5-NBRCHANGE: IPX-EIGRP 100: Neighbor BCBB000A.000a.b7ca.f280 (Tu
00:19:54: %DUAL-5-NBRCHANGE: IPX-EIGRP 100: Neighbor BCBB000A.000a.b7ca.f280 (Tu
00:19:54: EIGRP: Neighbor BCBB000A.000a.b7ca.f280 went down on Tunnel0
00:19:54: EIGRP: New peer BCBB000A.000a.b7ca.f280
00:20:03: %DUAL-5-NBRCHANGE: IPX-EIGRP 100: Neighbor BCBB000A.000a.b7ca.f280 (Tu
00:20:03: EIGRP: Neighbor BCBB000A.000a.b7ca.f280 went down on Tunnel0
00:20:04: EIGRP: New peer BCBB000A.000a.b7ca.f280
Is this a bug in the IOS or an I doing something wrong?
  • Other Network Infrastructure Subjects
1 REPLY
Re: IPX GRE Tunnel and Netware & EIGRP errors
You could refer to the document "What Does the EIGRP DUAL-3-SIA Error Message Mean?". It is available at http://www.cisco.com/warp/public/103/18.html.
Your error messages indicate that the neighbor adjacency is flapping due to the router going into the SIA state (Stuck in Active). It is the state where an unacceptable amount of time has passed since the transmission of a Query with no reply received. The document talks about the reasons due to which a router might go into SIA and how you could resolve the issue. Bug CSCdp33034 deals with the same. Also, Cisco IOS 12.1(4.4)E has certain enhancements that help resolve the SIA problem. If the problem persists, you could consider a switchover.
186
