01-16-2003 04:31 AM - edited 03-02-2019 04:14 AM
Has anyone gotten IPX to run over INTERFACE MULTILINK? I've gotten it to work with Virtual-templates & ipx ppp-client loopback, but no success when trying to use INTERFACE MULTILINK.
01-16-2003 08:52 AM
Works fine over Multilink interfaces.
Here is a RIP (IPX learned) network learned over a Multi link interface and a ping
R DD [31/01] via AA.aabb.cc00.2000, 6s, Mu1
R FF [31/01] via AA.aabb.cc00.2000, 7s, Mu1
R1#ping
Protocol [ip]: ipx
Target IPX address: dd.aabb.cc00.2001
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Verbose [n]:
Sending 5, 100-byte IPX Novell Echoes to DD.aabb.cc00.2001, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 100/117/132 ms
Is your Multilink showing up/up. Do you have IPX network assigned to your Multilink interface? If so, could you pls send your config (Multilink specific and IPX) so we can try to help you.
Hope this helps,
Don
01-16-2003 09:20 AM
Don,
This is what I have:
ROUTER 1
interface Loopback0
ip address 141.214.255.21 255.255.255.255
no ip directed-broadcast
ip ospf interface-retry 0
interface Multilink1
ip unnumbered Loopback0
ipx network 8DD6FF15
ipx output-network-filter 900
ipx output-sap-filter 1000
ipx rip-max-packetsize 1488
ipx sap-max-packetsize 1488
multilink-group 1
interface Serial0
description Ameritech T1 Circuit # DHZA835594
no ip address
encapsulation ppp
no ip mroute-cache
no fair-queue
pulse-time 3
ppp multilink
multilink-group 1
interface Serial1
description Ameritech T1 Circuit # DHZA870669
no ip address
encapsulation ppp
no fair-queue
pulse-time 3
ppp multilink
multilink-group 1
ROUTER 2
interface Loopback2
ip address 172.22.255.7 255.255.255.255
ip unnumbered Loopback2
ipx output-network-filter 899
ipx output-sap-filter 1040
multilink-group 1
interface Serial6/0/0:21
description O&P Ameritech T1 Circuit DHZA835594 Serial0
no ip address
encapsulation ppp
ip route-cache distributed
ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
interface Serial6/0/0:22
description O&P Ameritech T1 Circuit DHZA870669 Serial1
no ip address
encapsulation ppp
ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
Router 1 which is the remote show the ip routes going over Mu1 fine. When I do a show IPX server all I see is the servers on the LAN side. This works fine using virtual-templates and ipx-ppp client.
