IS-IS problem
I entered "router isis" in the config mode and this was supposed to put me in the "config-router" mode, but nothing happened. What's wrong?
IOS: 12.1, feature set: IP only, router: 2621.
Re: IS-IS problem
Jing,
The reason why you weren't able to configure IS-IS was the feature set htat you have doesn't support it. The feature set for a 2621 would have to be at least enterprise.
Here is a link to the HW/SW matrix in case you would like to check other features or platforms.
http://www.cisco.com/cgi-bin/Support/FeatureNav/FN.pl
Re: IS-IS problem
Thank you. But it needs more memory. Is memory on the router the same as the one on the PC?
83
